10-30-2016, 12:52 PM
Engine: gasser probably
Asking the pros. Good vs bad deal?
The tittle says it. I thinks is good deal, but add your opinion based on specs.
Mathies & Sons, Inc. - 422 Sales
Sent from my BLU LIFE ONE X using Tapatalk
10-30-2016, 12:58 PM
Here is another one that sold for 300!
http://onlineauction.422sales.com/cg...ales2/BWB013/9
10-30-2016, 01:54 PM
if it goes for less than $2000, its not a bad deal. low miles, is that some under body bins? hard to tell in the pics.
the cummins 5.9 with a 4.7 rear is just... ok. nothing much to write home about. it probably has the AT545 transmission. if it goes for less than 2k, i'd consider it a deal.
my bus is a 5.9 cummins with the AT545, its very similar to what youre bidding on.
i would look for a dt466, or a cummins 8.3, to bid on. and hope they stay under $4k.
my 2 cents
good luck
10-30-2016, 02:30 PM
I'm no pro but it has WAY more than four windows!
And from the description it sounds like it will need more than a tranny job.
Needs Serviced, Does Not Work. body damage: Slight Rust on Rear. Front Tires 35% Tread, Rear Tires 50% Tread. Brakes 80% Preview is recommended, Located in Freeland, PA.
10-30-2016, 02:34 PM
Hahha. Not for me. Just comparing prices.
I'm sticking to my 4 window short bus.
If it goes for less than 2k? They sold for 800 and 300!
Idk about buses but I just haven't seen many go for that low on govdeals.
10-30-2016, 02:38 PM
By the time you tow it and get it running you'd have thousands in it, most likely.
10-30-2016, 02:41 PM
Yeah. Maybe I miss read it. It thought they were refering to the AC services since it said run and drive.
10-30-2016, 02:46 PM
Engine: Navistar 7.6L
Did you notice the "This item has a reserve" at the end of the description?
I would bet good money that the owner did not let them go for the last bid on them.
Auction ended might not mean sold.
Ah, I didn't read it right. Says it runs and drives.
Time you put tires on it, it would still be a lot of money to get it home. Then to deal with the rust.
10-30-2016, 02:53 PM
That is very true.
10-30-2016, 02:54 PM
Here goes the 4 window.
http://onlineauction.422sales.com/cg...sales27/030343
10-30-2016, 03:20 PM
Looks like a nice bus, but where's it from?
10-30-2016, 03:38 PM
That's the wildest passenger side mirror setup I've ever seen!
10-30-2016, 04:26 PM
Texas I think.
Mirrors look exotic. Lol.
It probably has a high reserve.
