Old 06-09-2011, 10:55 PM   #1
sportyrick's Avatar
Chassis: F33695
BB All American rear door needed
I am in need of another rear door to use as parts to extend mine to haul larger motorcycles. I plan on cutting mine and your old one both in half, or just a little longer than half, and welding them back together to make a 6" wider door with only one seam. Does anyone have their rear door they took off and need to get rid of? Of course it has to match mine exactly which makes the one I am needing a Bluebird All American from the 70's or 80's, maybe even the early 90's? It could even have some damage on one side or the other and of course I can't use the windows because it will need to be longer when I am done so I would like them cut out to save weight and be safer in transit. I assume I can UPS it to my place but haven't checked. Does anyone think that will be a problem? dimensions are 34 13/16 W X 55" H thanks, Sportyrick
Old 06-10-2011, 10:55 AM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: BB All American rear door needed
a picture of your door would be good to. also good thing you got the measurements up there!
Old 06-10-2011, 03:53 PM   #3
houskou's Avatar
Coachwork: flatnosed
Chassis: amtran/bluebird/thomas
Engine: diesel
sr
seems to me that somone on here made a "second" door by cutting one side an articulating it with a hinge - I thnk it was meant to get wider things(toy?) in and out.
I 'llhave a look to see ifI can find it again.
The sun is the same, in a relative way, but you're older; shorter of breath, and one day closer to death.
Pink Floyd - Dark Side of the Moon
houskou is offline   Reply With Quote
Old 06-10-2011, 04:52 PM   #4
houskou's Avatar
Engine: diesel
SR
look on page two of this one
Haulin' Toyz - '85 GMC Skoolie in NJ
Perhaps you have already decided on your methodology- if so please forgive the unsolicited advice
Old 08-24-2011, 12:44 AM   #5
Engine: DT466C
Rated Cap: 60
Is this door different than an 88 BB conventional?
martian is offline   Reply With Quote
1984 Blue Bird All American Rear Engine Tango Skoolie Conversion Projects 13 11-28-2011 02:02 PM
Side door/ Rear door SeanF Conversion General Discussions 6 05-24-2009 12:56 PM
door lock needed keith Classifieds | Buy, Sell, Swap 0 01-04-2009 12:23 PM
needed Door hardware swinada Classifieds | Buy, Sell, Swap 17 12-06-2007 10:17 PM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 12:52 PM
