04-21-2016, 03:58 PM
#21
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Wonder if my 643 can have one added??? That sounds like a great breaking. Is your bus a 40'? Just curious about size and what not. Do you know the make/model of your retarder?
04-21-2016, 06:50 PM
#22
Originally Posted by Docsgsxr
A REAL Jake replaces the cylinder head and other stuff and will set you back way more than just an exhaust brake.
04-21-2016, 07:48 PM
#23
That Telma electromagnetic driveline retarder is cool! Seems like it wouldn't be too hard to retrofit onto an existing vehicle. Probably costly though. On some offroad vehicles (rock crawlers) they add a brake disk to the driveshaft and mount the caliper on a bracket. They use it to hold the vehicle in place while negotiating difficult climbs. I don't think it would work for high speeds though, would probably tear the driveshaft out of the vehicle or overheat severely.
04-21-2016, 09:13 PM
#24
I called Pacbrake and they have the same kit, get this, for 1400 bucks! Who would have thought Cat would be cheaper than an aftermarket company?!?
But I have the part numbers from Cat when i order it. I'm thinking, maybe in the fall......
04-21-2016, 10:18 PM
#25
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
This. Jakes with probably cost more than you paid for your bus.
04-23-2016, 09:48 AM
#26
Engine: T444e
How crucial is it to have one of these alternate braking systems, though? Prerequisite, if driving through the mountains? It seems that there are lots of folks here without them and I find it hard to believe that they would be avoiding all mountains and hills during their travels.
04-23-2016, 10:21 AM
#27
Jakes & retarders just take the "thrill" out of steep downhill driving!
But seriously...they are a real comfort and do save a lot of wear & tear your primary brakes. As for being a "necessity"...well, probably not...if you are a highly experienced driver of heavyweight vehicles in such conditions.
I can tell you that there are a number of otherwise beautiful mountain roads I would consciously avoid without them or at the very least, a fully locking tranny and a solid emergency brake. While I have no plans on tackling Black Bear Pass in my skoolie, I would like to get onto any number of the gorgeous paved roads in the area without too much white-knuckling or having to use the runaway truck ramps on a regular basis.
04-23-2016, 10:38 AM
#28
Engine: T444e
...and we are NOT highly experienced. Granted, we will likely be sticking with a short/midsized bus. However, would a basic exhaust brake do the trick? I'm trying to figure the best way to satisfy this precaution because it seems to be the biggest obstacle to us finding our bus (as we are still in shopping mode and on a rather light budget).
04-23-2016, 10:42 AM
#29
Tango is absolutely correct!!
i have the AT545 non lockup transmission and it the most exciting transmission on a long down hill. you have to rely on going slow and your service brake. the engine/transmission won't hold you back, making an exciting ride.
i wouldn't worry if i had any other transmission other than the AT545. the others 643, 3060,...et al, let you ride a low gear down a hill.
04-23-2016, 10:51 AM
#30
My 643 did ok when I went down Monteagle in TN, but the REAL mountains out west... I'd want a retarder.
You can get around having one, but we are talking about planning ahead here.
This is nothing compared to the Rockies!
04-23-2016, 11:00 AM
#31
it sounds like it ran nice N smooth.. what did you do take it down to 3rd gear?
I was out in utah this week for work and noticed almost ALL the school bus in the town south of SLC where i was were thomas and bluebird RE's (big long ones) and it sounded like they had Jake brakes.. now mind you I dont know the differenct between a retarder and a jake brake but it sounded loud like what the semis have...
04-23-2016, 11:08 AM
#32
I just put it in "3".
I doubt school buses have jakes. They're expensive. But the schools out west get a lot more funding than our third world schools in FL.
04-23-2016, 11:10 AM
#33
they also have real mountains to go up and down on regular school routes every day... whats the difference between a retarder and a jake?
04-24-2016, 08:18 PM
#35
Chassis: TC2000 RE
Engine: Cummins 8.3
Rated Cap: 78 passenger
Here's where I got mine. This sale is tomorrow, so no short notice or anything.
Scroll down. First bus is a front engine 5.9 24v, but I believe the rest are 8.3 Cummins engines with retarders. Some are ADA equipped, a couple aren't.
Good luck!
Roller and Associates, Inc.
