Old 12-19-2016, 11:32 AM   #1
Buses for Sale // 2000 - 2003 // Thomas & BlueBirds // Staring at
I have several buses for sale. Thomas & Bluebirds. See the list below to check out size and year model. Email me to get info on a specific bus. Mileage is between 100,000 -200,000 miles on most buses. All have diesel Cat or Cummins engines with Allison Transmissions. Prices starting at $5000.
List # Make Year VIN Eng / Trans Passenger Mileage
30 Thomas 2003 1T88UZD2131133250 52 146,162
16 BlueBird 2001 1BAAGCPA11F097833 Cummins / Allison 44
9 BlueBird 2001 1BAAGCPA91F097773 Cummins / Allison 44
23 BlueBird 1992 1BAAHCSAXNF051444 Cummins / Allison 44 50,396
19 BlueBird 1997 1BAGNBSA3VF075372 Cummins / Allison 53 80,687
25 BlueBird 2000 1BABNB0A9YF091867 75
5 Thomas 2001 1T7HN3B2511096727 Cat / Allison 72 150,000
18 Thomas 2003 1T88UZD2231133256 Cummins / Allison 52 157,375
21 BlueBird 2001 1BAAGCPA11F098075 Cummins / Allison 44
29 BlueBird 2003 1BAAGCPA53F209214 Cummins / Allison 44
24 Thomas 2005 1T7XU3B2651144437 Mercedes / Allison 81 157,000*
Click this link to see bus pictures. https://drive.google.com/open?id=0B5...FJ3Wk5wUTFCS2c
erichbean is offline   Reply With Quote
Old 12-19-2016, 12:49 PM   #2
Price for #9?
Starting at $5000 seems a little out there considering condition.
deftone is offline   Reply With Quote
Old 12-19-2016, 01:23 PM   #3
if someone buys #19, I want the Seats!!!!!!
Old 12-19-2016, 01:43 PM   #4
Engine: Navistar 7.6L
Where are they?
DoubleO7 is offline   Reply With Quote
Old 12-19-2016, 01:51 PM   #5
The Cummins powered Bluebirds, which Cummins? Which Allison?
Old 12-19-2016, 02:05 PM   #6
Answers
#9 - $6000
Located in Hattiesburg, Mississippi
Old 12-19-2016, 02:27 PM   #7
Rameses's Avatar
They're Cummins engines and Allison transmissions. Why would you need to know anything more than that?
Rameses is offline   Reply With Quote
Old 12-19-2016, 02:38 PM   #8
Because I REALLY REALLY want one with a 4BT and an AT-750...... Or was it an M11 and an AT-545....
I get sooo confused......
Old 12-19-2016, 03:54 PM   #9
Ive had no problems with my AT-545....
....In the 6miles or so the motor lasted
Old 12-19-2016, 04:25 PM   #10
you blew the engine that quick?
I thought you had it fixed..
Old 12-19-2016, 04:26 PM   #11
Good Questions....
I have zero idea about which model transmission and engine. Most of the 44 passenger BlueBirds appear to have the same Cummins engine but the valve cover doesn't specify a model.
I'll try to find out.
Old 12-19-2016, 04:34 PM   #12
Its not fixed yet, my work schedule has prevented me from getting back up there. i hope to get up during the xmas break
Old 12-19-2016, 05:12 PM   #13
prof.fate's Avatar
24...RE, under storage and the seats are out.
a couple of them have allison 3060's
prof.fate is offline   Reply With Quote
Old 12-19-2016, 08:03 PM   #14
HUGE difference in value between an AT545 and any later Allie tranny.
Old 12-19-2016, 11:40 PM   #15
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Find one with a representative engine and post the VIN: one can get the engine type from that. For the transmission types, the parts department can tell you from the VIN (at least the International guys can; presumably the other manufacturers can as well).
Dapplecreek is offline   Reply With Quote
Old 12-20-2016, 09:36 AM   #16
Bluebird dealers can do the same for you with Bluebird buses.
Old 12-20-2016, 09:47 AM   #17
Post pictures. Someone here will tell you which engine or transmission is pictured.
As far as the cummins go, the difference between an 8.3 and a 5.9 is pretty plain. If you look at the corner of the front engine cover where the injection pump mounts, the 8.3 has a radiused corner the 5.9 has a 45deg chamfer.
Also, the injectors on the 8.3 are on the same side of the engine as the injection pump. On the 5.9 the injectors are on the opposite side from the injection pump.
Old 12-20-2016, 09:54 AM   #18
Rameses's Avatar
That's only true of the 12 valve. On the ISB, the injectors were put on the pump side of the head.
Old 12-20-2016, 10:57 AM   #19
I stand corrected.
I guess the shape of the front engine cover is the best "tell tale".
Old 12-20-2016, 11:03 AM   #20
https://drive.google.com/open?id=0B5...i0xUnc2anhzUk0
Thats a link to the picture. For some reason, I can't get the pic to show up in the post. Hosting them from my google drive account.
The VIN for this Bus is: 1BAAGCPA11F097833
