Julius, that type of A/C should work in any bus where you have (usually) about 3-3.5 feet of skirt space along the bottom to mount the condenser.. and the evaporator can be mounted often times on one of the sides of the ceiling or axcross the back of the bus.. (it can be placed up front if you have the header room.. but usually makes for a head-bump spot up front)..
RED-DOT makes compressor brackets for about any engine.. and this would use a TM-16 / selttec8390 ear mount compressor easily,,,,
you can buy lines and burgaclip fittings to easily make your own freon pipes...
this set would save you tons from buying everything new from a Coach A/C company...
