Old 07-30-2010, 02:28 PM   #1
double decker bus
Found on CL
NOT MINE
http://indianapolis.craigslist.org/clt/1844091792.html
jbus is offline   Reply With Quote
Old 07-30-2010, 07:51 PM   #2
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Re: double decker bus
Originally Posted by Iceni John
What's he smoking? Whatever it is, I need some too. Maybe he means $1950, and his finger slipped as he was typing. Oh well, hope springs eternal.
It's a Bristol Lodekka FLF with the standard Eastern Coachworks body. I've ridden many a mile in Fluffs just like this in England, and I was thinking at one time of buying one to convert. Another member here has one, with the rare Bristol engine that gave him some grief, but they usually had bomb-proof Gardners. Where they get weird is their offset driveshaft and dropped-center rear axle, plus apparently they have left-turning engines (like V-drive GMC buses). It would be fun to have one here, as long as you could get all the needed parts and could work on it, otherwise it could be an exercise in frustration trying to keep it running.
Perhaps a stupid question, but since you've been around them a bit, how easy are these busses to repower into something a bit more domestic to the USA? Plus, how tall are these busses? Under 13'6"? Just thought I'd ask....
M1031 is offline   Reply With Quote
Old 08-03-2010, 09:34 PM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
Thanks John! I also did some research and ruled out this option.
Old 08-04-2010, 09:37 AM   #4
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
wow they sound like a real nightmare! upside down portal axles, reverse turning engines!
so does that mean you can get a normal engine, flip the portal axles and have an off road double decker?
Old 08-05-2010, 09:47 PM   #5
bus-bro's Avatar
Engine: 3208 na boat anchor
You could run a dt360 backwards if you had a camshaft designed to run the other way. Old direct-drive diesels on boats would switch cams and (hopefully) go the other way.
Old 08-05-2010, 10:29 PM   #6
frank-id's Avatar
Diesel / gas engines can operate either direction
It requires more than just a camshaft. The oil pump and fuel pumps would need some changes too. Many boats use a pair of matched engines the are made to turn clockwise and anticlockwise. If both engines turn the same direction the boat will make large circles in the water. Frank
Old 08-12-2010, 06:22 PM   #7
Coachwork: Ward Genesis
Engine: DT466/MT643
Chrysler Marine did this too. The cam turned OPPOSITE the crank rotation, so the oil pump worked as normal. Just needed the reverse-rotatiion cam & timing set.
Jarlaxle
DIY double decker adamanderr Conversion General Discussions 8 04-24-2016 09:50 PM
Making Our Own Double Decker bansil Conversion General Discussions 4 01-18-2013 04:08 AM
Double decker Slide out? lapeer20m Skoolie Conversion Projects 4 07-20-2012 09:31 PM
Double Decker Bus RV Conversion DragginVR Coach Conversion Projects 6 03-08-2012 12:19 PM
1960 Bristol Double Decker Bus Steve Classifieds | Buy, Sell, Swap 7 01-16-2006 12:04 PM
