Old 04-16-2019, 05:28 AM   #1
For sale 1974 Chevrolet C60 BlueBird
Due to financial and health issues I can not continue my project. I'm willing to sell my bus to recoup the cost of the new wheels and tires.
The bus is located in Prince George, BC, Canada. The bus needs a safety inspection to make it insurable.
My contact information is:
tootalltechie.gh@gmail.comClick image for larger version
ID:	31923Click image for larger version
ID:	31924Click image for larger version
ID:	31925Click image for larger version
ID:	31926Click image for larger version
Tootalltechie is offline   Reply With Quote
Old 04-16-2019, 10:29 AM   #2
Rovobay's Avatar
Rated Cap: 35
Oops..... you forgot to list the price!
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 04-16-2019, 11:07 AM   #3
Or any other pertinent info on the bus.
Old 04-16-2019, 12:01 PM   #4
This is his build thread. http://www.skoolie.net/forums/f11/my...dow-14789.html
Disastrogirl is offline   Reply With Quote
Old 04-16-2019, 12:14 PM   #5
Propane bus, No Thanks.
Old 04-16-2019, 12:57 PM   #6
Price, the cost of the wheels and tires. 5000
Old 04-16-2019, 05:20 PM   #7
Ronnie's Avatar
Engine: 345 international V-8
Thought Sleddgracer was looking for a gasser. He is in BC as well.
Old 04-16-2019, 05:26 PM   #8
It's not gas, it's propane.
Old 04-16-2019, 05:38 PM   #9
Ronnie's Avatar
Same basic engine, could be changed to gas easily. Good canidate for fuel injection at least a TBI or better yet multi point EFI
Old 04-16-2019, 06:09 PM   #10
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
some of the 366's came converted to propane from the factory with hardened valves
Old 04-16-2019, 06:21 PM   #11
Well then, there's the start to your conversion.
Old 05-02-2019, 02:31 PM   #12
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Definitely really cool looking! Sorry to hear you won’t be able to complete it and enjoy the conversion. From the pictures I saw in your build thread it looks like once it’s all complete the bus might be over GVWR.
WARGEAR is offline   Reply With Quote
Old 05-02-2019, 04:46 PM   #13
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
How does the propane tanks do in your extreme cold?
Do you have blankets to wrap the tanks or have to insulate the gas lines?
Old 05-02-2019, 04:55 PM   #14
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
my truck would start at -27 c ( -16.6 f ) without being plugged in - hit a lot of steady -35 c ( -31 f ) that winter, and some colder than that, but had no trouble starting the truck - the morning we were leaving Yellowknife, was the coldest we saw, and all the propane outlets with one exception were frozen, but the truck had started ( then the thermostat seized shut, and had to start and stop, start and stop to cool down until we came to a one service station small town - they had one thermostat on the shelf and it just happened to fit my chevy truck - damned cold on the hands to change the thermostat at -40
Old 05-02-2019, 05:53 PM   #15
Year: 86
Chassis: Ford B700
Engine: 8.2
I bet.
I don't see anything like that here?
Was just wondering cause last year when we got 2' of snow?
I had to fix someone else's mess on a roof top where they didn't figure in the snow load or windchill for 16 HVAC units and the regulators froze up cause they only had them 4"s of of the roof and mucked an entire shopping center up?
Mainly cause the regulator vents were froze.
If you bought a propane bus in your area then I can assume it was built for your area.
Hopefully it was done correctly when it was installed for your area.
Instead of propane the natural gas companies are running there stuff off of natural?
Just an orifice and regulator gut change but I don't know if it's better or if it's free cause they are the ones that's drilled to get it?
Good luck,have fun
Old 05-02-2019, 06:17 PM   #16
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I bet.
Good luck,have fun
as far as I know, all of the propane powered buses I've run into were factory conversions - the natural gas company in this rural area must have a pump in their own yard if they are burning NG because there is certainly no availability for automotive NG in this area - I did see a bus advertised that was equipped dual fuel, NG and gasoline
Old 05-02-2019, 06:36 PM   #17
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
tootalltechie.gh@gmail.comAttachment 31923Attachment 31924Attachment 31925Attachment 31926Attachment 31927
I was just checking out your build pictures and wondered if you know for sure that it's a 350 cui motor - a lot of the buses from that era were equipped with a 366 - a 350 is pretty small for a bus that size, I would think
Old 05-03-2019, 09:55 AM   #18
I do not know for sure but I do know it can't be original. The odometer is wrong. It has a 2 barrel carburetor, elk horn exhaust manifolds, engine has been poorly painted possibly 3 times( blue, orange, blue, the ignition system is HEI. I have tried to read the numbers off the block with out success. I think the block has been decked at least once. I have not done a compression test on the engine.
Old 05-03-2019, 10:02 AM   #19
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
[QUOTE=Tootalltechie;323318]I do not know for sure but I do know it can't be original. The odometer is wrong. It has a 2 barrel carburetor, elk horn exhaust manifolds, engine has been poorly painted possibly 3 times( blue, orange, blue, the ignition system is HEI. I have tried to read the numbers off the block with out success. I think the block has been decked at least once. I have not done a compression test on the engine.[/QUOTe
the VIN will have that information - ask any dealership or most/many mechanics and they can tell you what motor you have - just did some research, and the 366 did/does come with a 2 barrel carb
Old 05-03-2019, 08:32 PM   #20
[QUOTE=Sleddgracer;323320]
Decoding:*C S E 6 2 4 1 300241 DigitUsageVINDecoded
1 Mfgr (C) Chevrolet
2 Chassis (S) School Bus
3 Engine (E)V8 366 opt. 350 gas
4 Series (6)2 ton C50 class 5 (16001-19500lb)
5 Body (2)Forward Control Chassis/Cowl Only
6Year (4)1974
7Plant (4)Oshawa ON 8-13Sequential Serial #300241. 300241
