Old 04-23-2019, 02:06 PM   #1
FOR SALE 2002 Bluebird (OFFICIALLY TITLED MOTORHOME)
2002 Blue Bird MD/HD Trk All American FE AAC3109-3400 5.9L MFI Turbo Dsl 6cyl
*180,000 miles
* diesel
* Cummins engine and Alison transmission
* air compression brakes
* re-titled as motorhome officially
* 36’ long
* no passenger seats
* subfloors still intact, likely some rust on floors. Back door has small rust spot partially fixed. Exposed floor spot is access to diesel tank.
* driveable in great condition. I bought it in 2018 directly from a school district. Meaning it was impeccably maintained as per safety regulations for school busses. I had it evaluated by mechanics to make sure it was road worthy and all found no issues. I drove this bus from New Jersey to washington state this summer and had no mechanical issues! The front drivers heaters are the only thing that doesn’t function and needs repairs. This bus is located in WA state.
Asking $9500 OBO
ltoltz is offline   Reply With Quote
Old 04-23-2019, 02:29 PM   #2
FYI, you are going to want to update this ad with what engine and transmission the bus has, "a cummins engine and allison transmission" lacks the model specifics 99.999% of the people on this forum will want to know.
Information about maintenance records, and any rust present or repaired will probably also be requested.
Shelby987 is offline   Reply With Quote
Old 04-23-2019, 02:38 PM   #3
Rovobay's Avatar
Rated Cap: 35
https://www.govdeals.com/index.cfm?f...18&acctid=5774
any rust issues? I can see some rust in the floor where the plywood has been removed. Can you verify the Allison transmission model?
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 04-23-2019, 02:42 PM   #4
I updated the original post to include the information you requested
Old 04-23-2019, 03:14 PM   #5
Someone will still need to know the transmission model. The data plate inside the bus should list it specifically, or it might just have a serial number that you can use to cross ref. on the allison web page.
It will probably read AT545, MT643, MD3060, A1000, A2000......someone that knows bluebirds better then me will be here in a min. to confirm that 3 of the 5 listed were never available on this TC2000 platform in 2002.
Old 04-23-2019, 03:16 PM   #6
Bought at auction then marked up $7500, ouch
o1marc is online now   Reply With Quote
Old 04-23-2019, 03:19 PM   #7
Awww, Come on Shelby.... Wouldn't you buy a car based on " Ford engine and Ford transmission"?
Old 04-23-2019, 03:22 PM   #8
The motor is listed in the first line of the reply. At that price does the answer to any of these questions even matter?
Old 04-23-2019, 03:26 PM   #9
Rovobay's Avatar
Rated Cap: 35
I am no Allison expert but I am not sure if a 3000 series had a shifter similar to the one in the picture. Could be wrong.
Also note in the comments in the auction listing. That at time of sale
"Q: Hello size of motor trans size? Is there and overdrive? Is motor governed? Tire condition? Thank you (2/28/18 8:25 PM)
A: 5.9 ISB with a 3000 series transmission. Tire have some tread, there is governor and no overdrive (3/1/18 9:44 AM) "
Old 04-23-2019, 03:31 PM   #10
Haven't seen a 3000 series with anything other than a push button digital shift. Says no overdrive, it's a 545.
for sale
