Old 05-06-2019, 06:57 PM   #1
Great Propane/Waterheater Deal
I saw this on the local Craigslist. Can't use it myself, but if I could I would jump on this, tank alone sells for $
https://atlanta.craigslist.org/atl/r...876647390.html
Old 05-07-2019, 07:22 AM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
Heard back from the seller. Wants to stay local, cash, & doesn't know how to ship the tank. How'd you like to keep the heater and I'll take the tank? It's exactly what I'm looking for! Shoot me a PM to arrange the details, if you're game.
Old 05-07-2019, 11:42 AM   #3
Could you use a bigger tank? I have a 29.2 ga. tank just like that for sale.
Old 05-07-2019, 11:53 AM   #4
HazMatt's Avatar
Being an American, it is firmly inculcated in my consciousness that bigger is better!
What're it's dimensions, and what would you take for it?
I have 2 20 pounders that don't see much use with shore power at hand. Lighting out for the territories with a big bottle bolted to the belly would be optimal for boondocking.
Old 05-07-2019, 12:39 PM   #5
Being an American, it is firmly inculcated in my consciousness that bigger is better!What're it's dimensions, and what would you take for it?
It's 48" long, still in the box brand new. Runs $500+ new. I have it listed for $435, I'd take $400 for it.
Old 05-07-2019, 02:09 PM   #6
HazMatt's Avatar
Howzabout width and mounting points? Got similar flanges on top?
I have no understorage compartments, so will have to gin up a way to suspend it. Original plan calls to frame in a compartment behind RR tires to stow my little bottles. I'll need to check dimensions again, but should ought fit, especially after re-routing the tail pipe.
(Thems some propane accessories I could get behind!)
https://www.google.com/imgres?imgurl...source=sh/x/im
Old 05-07-2019, 05:23 PM   #7
The ribs running side to side on the floor are spaced perfectly for the 48" bolt spacing on the tank. I removed the tail pipe from the left rear of the bus, mounted the tank to the ribs and then cut in an access door for it.
https://www.ebay.com/itm/Horizontal-...frcectupt=true
Old 05-07-2019, 08:03 PM   #8
HazMatt's Avatar
That is the exact spot I've had in mind all along. 4' worth of tank will fill that soon-to-be void very nicely. Particularly since my propane hose is already routed out behind the shotgun tires.
Are the holes 48" center to center? If we get a spate between the squalls (2.7" ppt just this afternoon!) before Sunday, I'll grab my snorkel and measure me some exact rib #s.
In one of the pix you posted on my thread, it shows the ribs on your bus look like the letter, "U." On mine, they look like a capital H that got tipped over.
If still upright, dimensions of the H are:
Top to bottom: 9.25"
Bottom of 1 H to top of next: 6.5" (open gap)
From 1 leg of H to the other: 2 3/16" (headspace)
So, on that last, would bolts @ that size be long enough to secure the tank? I should ought be able to do the install from either end, underneath. If longer's needed, I suppose I could drill larger &/or angled holes.
Where'd you score that sweet door?! If I can't put a fill fitting in the wall, or it isn't recommended, I gots to get me one of them!
Old 05-07-2019, 08:07 PM   #9
HazMatt's Avatar
Forgot: what's it weigh in at, @ 90 lbs?
Old 05-07-2019, 08:15 PM   #10
Are the holes 48" center to center? If we get a spate between the squalls (2.7" ppt just this afternoon!) before Sunday, I'll grab my snorkel and measure me some exact rib #s. In one of the pix you posted on my thread, it shows the ribs on your bus look like the letter, "U." On mine, they look like a capital H that got tipped over.
The tank mounting holes are on a 48" center. You've lost me on your dimensions, post a pic.
Door was $18, shipping was $22.88. I got it for the locking feature before I was informed it's illegal to lock access to the propane tank.
https://www.ebay.com/itm/RV-Trailer-...72.m2749.l2649
