12-09-2015, 06:06 PM
How much is this bus worth?
Howdy,
My wife and I are looking for a bus to convert. I've found a 2001 Thomas rear engine with pass thru under belly storage, 5.9 cummins, MT-643 trans, 51,000 miles. Someone evidently started to convert. Already painted blue with white top. Did good job on paint. He's asking $6500, which is more than I was planning on spending. But its so low mileage I wonder if its worth it. The bus is only 1/2 mile from me, so it wouldn't cost me anything to get it home.
I'm thinking that the low mileage, not having to paint, and not having to bring it home from out of state may make it worth it.
I would really appreciate some feedback, as I have no idea what its worth. I don't want to be taken advantaged of, but don't want to miss a good deal either.
Thanks in advance for your advice.
12-09-2015, 06:10 PM
Coachwork: Crown by Carpenter
Rated Cap: 16
I would be a bit leery of a 2001 having 51,000 miles - that seems really low for that year. If there are records to confirm that, the price isn't so bad. Maybe a tad more than I would want to spend - see what you can get 'em down to...
12-09-2015, 07:05 PM
There are so many variables in regards to bus pricing it is hard to know for sure what you have.
Most school buses average 10K miles per year of service. It is not very likely the bus has only 51,000 miles.
Most school buses of that type with those options would retail in the $8,500.00-$16,000.00 range--higher=more options and lower miles, lower=fewer options more miles. Normal miles would be in the 135,000-155,000 mile range.
A good paint job to cover up the yellow is going to cost at least $2K for minimal prep work and using a very inexpensive paint like fleet white. Most school districts figure that for a good paint job they will have to pay $5,000.00 to paint a 35' bus.
If the bus is mechanically sound and the paint job is a good paint job that isn't going to peel the first time you go to scrub it clean I would say you are looking at a bargain, particularly if it is that close to home.
Good luck and happy trails.
12-09-2015, 08:21 PM
Thanks guys for your input. It seems like you both doubt the mileage. I am skeptical as well. Haven't had the opportunity to drive it yet. He tried to start it but the batteries are dead. I hope that isn't indicative of a more serious electrical issue. He said he'd put it on a charger so I can drive it. Also said he'd put new batteries in it if I buy. I suppose I'll drive it, see how it performs and how it's geared. If it seems sound I'll see how low I can get the price.
Forgot to mention its a14 window bus. 28" Windows.I'm guessing 32' from behind driver's seat to back Window.
12-10-2015, 09:37 AM
Rated Cap: 16
Definitely take it somewhere to be able to see what kind of cruising speed it can do. If you take it out and it runs well, sounds good and seems like a good deal, I'm in agreement with Cowlitzcoach - go for it! It seems like there could be a lot of positives with that one.
Good luck and let us know hoe it goes! Also, pictures. we love pictures.
12-10-2015, 10:20 AM
Had a friend year ago who when he was shopping for his first bus, cut a deal with one of the local school district maintenance chiefs to go over whatever he found for thirty minutes for fifty bucks cash. Wound up passing on a couple but the unit he settled on was an outstanding buy. The $150 he spent undoubtedly saved him thousands over time and to my mind was a brilliant investment.
12-10-2015, 02:58 PM
Has the title been converted to RV yet? Still have the seats in it?
12-10-2015, 05:06 PM
If you can test drive it, measure out a route or use a gps to measure how far you actually went vs how many miles the odometer changed that should give you an idea of how many miles it actually had when you apply the difference to the odo. So what you would do is if you went 10 miles but the odo says you went 7 you would take 10( actual miles driven) divided by 7(miles gauge says you drove) which gives you 1.43 (the fudge factor) then take that times the miles on the odometer and that would be the approximate max miles on the rig.
12-10-2015, 05:19 PM
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
My guess on the 51xxx miles is the gauge doesent work. The gauges that go into busses are usually garbage. One of mine is 62xxx KM and that gauge has not moved in the last 300 KM.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
12-10-2015, 06:13 PM
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
...was the speedo replaced? Mine was at 225000 kms., bus company had a sticky under speedo with the mileage when it crapped out.
12-10-2015, 06:18 PM
Thanks so much for all of the advice. I haven't had time to see it again. Planning on going back Saturday. As regards the odometer, I thought about that. Went home for thanksgiving this year with cruise set I 80. Got a ticket for 84 in a 75. On way home checked Google Maps against odometer and found 5 percent discrepancy. 4 is 5 percent of 80.
I don't know if it has an RV title. 2/3 of the seats are still there. Has a table and chairs and a unfinished wall. Also has a sprung emergency door.
12-10-2015, 07:12 PM
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
me? I have no reason to believe it was. the whole cluster on that bus is dicker'd. The only gauge that works reliably is the oil pressure gauge....because it is mechanical.
12-10-2015, 11:29 PM
Chassis: Blue Bird
Engine: ISC 8.3
Being a 2001, that 5.9 surely must be electronic controlled, in other words, the ISB engine. I like 'em fine, but plenty of people here prefer the older mechanical injected kind. That said, here's one point where the electronic can actually help you out: the ECM tracks engine operating hours. IIRC it also tracks mileage. If you can find somebody with Cummins INSITE software and an interface cable (not OBD2) they can pull that information from the ECM and advise you whether the mileage on the odometer is plausible or not. I think there was a flag in my ECM indicating whether it was original or replacement as well, but it's been a year and I don't remember all that well anymore.
In the case of my bus, I learned (some time after buying it) that its mileage was respectable at 287,000, but it had 21,000 hours on the engine! Ouch! Must have spent a LOT of time idling.
