Old 05-11-2012, 10:45 AM   #1
Re: In search of a skoolie or shortie or...
i would look mostly on this planet as fuel would be prohibitive if ya drive it back from mars...
Old 05-11-2012, 10:34 PM   #2
Exactly---Meow
Old 05-13-2012, 12:51 PM   #3
if ya want a hippie bus, look in huntsville alabama craigslist for a cheap low mileage 92 or so flat nose about 75 passenger...you will be able to tell it from its paint job.
Old 05-13-2012, 03:38 PM   #4
no, there is another flat nose one like 1992 with only something like 180k miles on it. painted hippy colors....
look again.. i dont think this old white one has been run for a long time... and the newer one is cheaper
Old 05-14-2012, 09:03 AM   #5
i would see if it has a rear wheel hub meter.. after all, it has only 117k miles on it, so mechanically it should be really good. and i would also check if there is rust on the frame, etc. with that low of mileage, it should be very good i think. ky aint so far from there...
Old 05-14-2012, 09:06 AM   #6
2850..i bet they will go down a bit for cash sale.. just saying
our alabama propety is 20 mi e of huntsville.
Old 05-14-2012, 09:33 AM   #7
i think i just answered your question in another post of yours....
Old 05-14-2012, 09:50 AM   #8
Rated Cap: 47
Is the plan to park the bus and live in it or will you be travelling? Long trips or short trips?
Motobus is offline   Reply With Quote
Old 05-14-2012, 11:24 AM   #9
Send a message via ICQ to mightybus
I would pick up the MCI in a new york second at that price.
mightybus is offline   Reply With Quote
Old 05-14-2012, 12:17 PM   #10
bus-bro's Avatar
Engine: 3208 na boat anchor
Yeah, on the MCI. Though the price seems to good to be true.
Old 05-14-2012, 12:33 PM   #11
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
While the MCI would probably be the quickest to get going in, if anything goes wrong especially with motor or transmission it will be the most expensive to fix. Even if you have the know how to do it yourself. Of the three I think the Bluebird would be the most reliable least expensive to fix.Don't buy anything that you can't hear run and take for a drive, especially since you indicate you know nothing about buses. If you aren't prepared/able to to much of the work yourself, labor will eat up that $$$$ quite quickly.
Good luck.
TIP: Better skoolie.net search jazty Forum Admin | Account Help | Suggestion Box 5 08-05-2016 02:23 PM
Bus Search busdriver_phil Short-Bus Conversion Projects 1 03-25-2011 02:06 PM
New Skoolie with a shortie (HELP!) hazelhermit Short-Bus Conversion Projects 3 06-18-2009 08:40 PM
My search is over! rereid Everything Else | General Skoolie Discussions 6 10-14-2007 10:41 AM
sKOOLie search and seizure - "mobile home" legalit skoolie_grease Everything Else | General Skoolie Discussions 19 01-23-2006 04:04 PM
