Old 07-20-2008, 12:51 AM   #1
Coachwork: thomas
Chassis: gmc
Engine: 366 gmc
inverters
need to know if a 3000 watt inverter with 2 deep cell batteries will power lights and a 120 volt refridgerator
and a furnace blower, and for approximatley how long
dwheward is offline   Reply With Quote
Old 07-20-2008, 01:40 AM   #2
swinada's Avatar
Re: inverters
all depends on the size of your batteries. How many AMP hours do they hold? How much is your fridge and your furnace drawing, etc.
WELCOME to the best Skoolie site on the WWW. I see you signed up last year but never posted before, so look around and you will find lots of information, also about the question asked.
Here a very helpful link to your battery question. http://www.phrannie.org/battery.html
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 07-20-2008, 04:55 PM   #3
the_experience03's Avatar
Re: inverters
Watts, watts, watts. You need to find out how many your devices draw. The lights will be easy. You do plan on going LED or fluorescent, right? The fridge will have a tag on the back that will say 1.2 amps, 120 volts AC, 60 hz or something to that extent. Watts are just amps times volts. The same goes for the blower. It should have a rating plate on it as well. You will also have to figure out how often those items will be running since neither is a continuous duty application. Get that much information and come back to us and I think we will be able to help. Lord knows every one of us went through the power system design process.
use of inverters putterspitt Electrical, Charging and Solar 4 11-25-2010 09:06 PM
Inverters.......ugh opus Electrical, Charging and Solar 6 10-31-2010 04:23 PM
Input on inverters. crazycal Conversion General Discussions 6 06-04-2010 07:09 PM
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 08:46 AM
cheap power inverters batchlor BusMan Everything Else | General Skoolie Discussions 2 04-06-2004 05:02 PM
