Old 09-02-2019, 08:58 PM   #1
Rivetboy's Avatar
Lady Liberty for sale
5.9 just overhauled long block up 158000 runs tremendous newly rebuilt at 545 pro rebuilt turbo and air compressor 1 a c no belt blue cold not hooked back needs wiring and a bit of lighting install to drive current tags 100 miles on 6 new tires make offer in Los angeles area plenty of posts and pictures here documenting the build
Rivetboy is offline   Reply With Quote
Old 09-02-2019, 08:59 PM   #2
link to the build thread?
Old 09-02-2019, 09:05 PM   #3
What??? WHy the change of heart? You put so much effort in!
Old 09-02-2019, 09:36 PM   #4
Rivetboy's Avatar
no build thread just my posts here
Old 09-02-2019, 09:42 PM   #5
Ayup, found the posts by searching Lady Liberty in the search bar. Lots of work went into this bus!
Old 09-02-2019, 09:43 PM   #6
Rivetboy's Avatar
also new front drums and brake shoes all the way around and transcooler with fan and thermostat and braided lines with AN fittings.
Old 09-02-2019, 11:15 PM   #7
I just went to look it up here. Holy Why oh why are you selling after all that work? I would be all "you are burying my butt in that dang bus!"
richellekohler is offline   Reply With Quote
Old 09-03-2019, 01:39 AM   #8
Yes, the age old question of why .....
Old 09-03-2019, 06:01 AM   #9
How much are you asking?
Daley is offline   Reply With Quote
Old 09-03-2019, 09:15 AM   #10
Rivetboy's Avatar
best offer
Old 09-03-2019, 11:17 AM   #11
Rivetboy's Avatar
best offer
6 tires were $3500 they have 100 miles on them and have been inside AT 545 is a fresh rebuild..5,9 has had everything replaced without removing the head, IE rebuilt turbo and brake air compressor.harmonic balacer front and rear seals, oil pump, water pump, fuel pump, cooling fan, Derrale fan trans oil cooler , fuel lines, check valve,all filters,all gaskets, belt, fan, front and rear mounts , A Thousand bucks in instruments that need to be installed the list is long. PM me for more information. Also, relocated fuel tank to drivers side. Needs wiring, starts and drives fine. Starts right up with no smoke.
Old 09-03-2019, 01:23 PM   #12
Rivetboy's Avatar
I am asking 10K for it
Old 09-05-2019, 11:24 AM   #13
Do you a pictures or a link?
SAge59 is offline   Reply With Quote
Old 09-05-2019, 12:34 PM   #14
Zona_The_Bus's Avatar
Chassis: international
but why are you selling it (((
Zona_The_Bus is offline   Reply With Quote
