Old 07-26-2007, 10:33 PM   #1
Year: 1970
Engine: Ford
LOOK HERE!
This is a 1970 Blue Bird All American Bus. It was modified by Lee's Custom Coaches into a Bloodmobile. It is 30' long and we decided that we want a larger bus.
It is powered by a 391 Ford Industrial engine, and a 6 speed MT40 Allison automatic transmission. I drove it home over 400 miles w/o ANY problems except the brake master cylinder went out.
It has a bad wheel cylinder on the left rear which I bypassed to drive it home. It had bad gas in the gas tank so I used an auxiliary tank and electric fuel pump to get it home. The fuel tank has been drained.
I have gutted the inside and you can fix it however you want it.
The rear ac works intermittently (like a capacitor is cutting in and out). The front ac blows but the compressor does not run.
There was rust in the rear cap and I have removed it but it will be easy to form back.
IF this bus does not sale by August 15, I will strip it, sale the engine and trans and used the solid body panels on my new bus.
$800.00 OBO
Angler is offline   Reply With Quote
