Originally Posted by jMyles
The metal interior? I own a skoolie and I'm still learning so many basics every day. So, mine still has the metal interior. Do most people remove it? What is this called? Is there a guide to this? What are the advantages?
If the bus still has the aluminum panels on the sides and the original metal ceiling then that means that there is a very strong possibility that the original fiberglass batting insulation is still behind the side panels and ceiling. That insulation is notorious for harboring mold and critters and has horrible insulation properties.
If you're going to spend any length of time living in the bus then you are better off taking the side panels and ceiling off so that moldy insulation can be removed and better insulation can be installed in it's place.
Josiah is doing a great job on his bus and you can get an idea of how to take those panels down on his site:
http://www.skoolie.net/forums/f11/re...ess-11820.html
