Old 05-26-2015, 10:58 PM   #1
frank-id's Avatar
Looking for Gillig power steering gearbox
Bus is 1976 636, Cat 3208. Needs replacement gear box. Box has about 1/2 turn slop just in the gearbox.. Power steering pump also needed. Now owner drove bus about 1200 miles.. He said he was tired of steering. Any information appreciated about repair or exchange or parts. Box is made for power steering. Frank frank.id.crownatgmail.com 120842359 69
Old 05-26-2015, 11:58 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Try Patrick in Fresno. He used to part out Gilligs and Crowns.
I'm hungry!
You Gotta Let Me Fly
Old 05-27-2015, 04:53 PM   #3
Rated Cap: 40 Prisoners
You might see if redhead steering in Seattle can repair or rebuild it for you. Have
you tried adjusting gear mesh on the box. It's usually a large screw with a lock
nut and its best to adjust with the wheels off the ground so you can test for
binding as you run it lock to lock. Most truck repair manuals have instructions.
