10-15-2016, 01:58 PM
Chassis: 3000
Engine: 7.6 L / DT466
Rated Cap: 72 Pass.
Looking for RE adventure bus!
My fiancé and I are from Savannah, GA interested in an RE bus. I heard that IHC DT466/530 or Cummins 8.3L/ISC in 285-325 are good ones to consider. I would like something for long distance. What type of specifications should I be looking for? If you know of anyone selling or you yourself are selling let me know!!
Does this look like a good bus? I think this a city/school bus instead of long trip-going over mountain type of bus, but might as well ask.
https://atlanta.craigslist.org/wat/cto/5792301229.html
Also I attached some floor plans if anyone is interested! Let me know which ones you like the best.
Thanks
10-15-2016, 07:48 PM
You have several floor plans that look really nice. What I didn't see is a floor plan where you can walk around the bed.
Trust me when I say this, having a walk around bed is no longer a "nice-to-have feature" at dark thirty in the morning and you have to go to the bathroom and you are next to the wall.
If you are under the age of 30 you probably won't understand this. But again, trust me on this, the importance of having a nice comfy chair in which you can sit at the end of the day can't be stressed enough.
I have seen several floor plans that included a drop down panel to cover the stair well so that the co-pilot could sit with their feet on the floor. Those that had co-pilot seats like that built them so that they could swivel at least 180*. In that way the seat could be used not only when going down the road but when the bus was parked as well.
Avion made three different floor plans for their tri-axle trailers. One had a rear bathroom, one had a side bathroom, and one had a pass through bathroom. Of the three, the 34X with the rear bedroom and pass through bathroom is the most sought after. The difference between the pass through and the side bathroom is instead of all of the plumbing being on the street side the pass through bathroom had the toilet and basin on one side and the shower/tub was on the other with the hallway between. With doors on either end you could close off the bathroom for privacy. And instead of having a bathroom the size of a phone booth you have a bathroom with enough room to stretch your arms all the way out. http://www.gradeless.com/avion/1988/1988.pdf
10-15-2016, 08:06 PM
By the way, the IC RE bus for sale for $3,350.00 doesn't look like a bad bus and the price is very reasonable.
If the bus has the DT466 it is a real bargain.
If the bus has the T444 it is an okay bargain.
The DT466 will push that bus down the road, uphill and down, with very little "effort".
The T444 will do okay on the flat but will slow way down on the hills and will do everything as if it was huffing and puffing to do it.
10-15-2016, 08:09 PM
I put my bed across the wheel wells and it was awesome. Not too big a hassle to either go around the back ddoor or stp over it....for the first TWO months! After that i moved it to the side and asked myself "oh why did i put myself through that for two months!"
10-15-2016, 08:51 PM
Year: 1994
Thanks
What program is this for doing lay outs.
10-15-2016, 08:59 PM
Chassis: 3000
Rated Cap: 72 Pass.
Haha, Ive had the wall side of the bed for almost 4 years now. I actually prefer to be cozy in the corner and when I wake up I can usually crawl over the legs to get out. The foot of the bed is also blocked off with a dresser. I like small tiny spaces, so I hope it will work for a 6 foot male and 5'11 me.
I love the idea of a cover for the stairs and a swivel chair for the driver!
That $3,500 seems like a good one! I talked with the man and he's sold over 200, drove them all home from 700 miles away. It supposedly has a 2015 engine! Maybe thats my bus!?
10-15-2016, 09:02 PM
Chassis: 3000
Rated Cap: 72 Pass.
The program is Adobe Illustrator CC 2015. I have it since I do graphic design. Its pretty $$ but fun!
10-15-2016, 09:09 PM
Chassis: 3000
Rated Cap: 72 Pass.
I was looking at this one too! They said it was a former school bus so maybe its not equipped for long mountainous rides, or maybe not. Should I be looking for a DT466?
Its a 1991 Blue Bird TC 2000 72 passenger. Completely refurbished since 2013 with new paint, engine, transmission, alternator, tires, radiator, and other new parts. 5.9 Cummins turbo diesel and Allison automatic transmission. 151,000 miles.
https://atlanta.craigslist.org/nat/cto/5826991114.html
I saw this one too. Same guy as my first post. 1998 International 3000 AmTran School Bus. 147,xxx Miles. Caterpillar Diesel.
https://atlanta.craigslist.org/wat/cto/5803976103.html
10-15-2016, 10:57 PM
Year: 2005
Engine: Detroit MBE906
It looks like none of the floorplans had access to that left side emergency door that's standard equipment rear engine buses anymore. You want to keep that and all other emergency exits accessible just in case, heaven forbid, something should happen and you need to beat a hasty exit.
10-16-2016, 07:39 AM
Guy seems to REALLY hype up his used buses.
10-16-2016, 10:29 AM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Same with the rear window exit as well. Besides, it's also a nice bit of ventilation in the back with a window screen
10-16-2016, 12:45 PM
Year: 2005
There's a thought.... not sure how putting a screen on it would be done but it's something to consider.
10-16-2016, 12:48 PM
Chassis: 3000
Rated Cap: 72 Pass.
Thats a good point! Im not even sure what bus I'm getting yet, if it has an emergency door or not. Ill definitely keep that in consideration when doing the floor plans.
10-16-2016, 03:30 PM
Year: 2005
It's been a long time since I've seen a bus that DIDN'T have at least one side door, some rear engine buses have two (not a lot, but there are a few out there).
10-16-2016, 07:10 PM
I have one on the left plus the rear window, and that seemed pretty standard at the ones I looked at.
10-16-2016, 07:11 PM
Great looking floorplans!
Small world, I am actually in Savannah right now for work.
10-16-2016, 09:47 PM
Chassis: IH
I would steer clear of the Cummins 5.9 for much long distance travel. It's *OK* for flatlands travel, but will struggle up long hills.
I would also steer clear of Cat engines - the older 3208 (V8 style) engines weren't one of Cat's best engines, and even the more modern and much improved engines aren't bad ... but they are more expensive to work on, and you can *ONLY* get parts from a Cat dealer. Which could be a really bad thing when you break down ... at 6:05 P.M. ... On a Friday Afternoon ... In the middle of nowhere ... on a long holiday weekend ... (In other words, you'll be stuck until the nearest Cat dealer re-opens the following business day).
I'm not far from Atlanta, if you'd like an experienced driver to help go over any prospective buses with you.
10-16-2016, 10:17 PM
Rated Cap: 37,400 lbs GVWR
Essentially any bus conversion is designed around the toilet! The poo tank should be on the driver's side so its dump valve is somewhere just ahead of the left rear wheels - that's where most dump stations are set up for. For minimum flush water usage and simplest plumbing the loo should be directly above the poo tank, so the loo ends up being on the driver's side towards the rear. Once the loo's position is established, everything else just falls into place.
I'll have a queen-size bed with side access on both sides, and directly forward of it a floor-to-ceiling 25"-deep closet on either side - this will effectively extend the bedroom forward and make it feel much larger. Ahead of the closets is the bathroom on the port side and a nice big shower on the starboard side, ideal for two people who want to shower and pee at the same time! The kitchen is set up with the sink on the right side just next to the shower head to minimize hot water pipe lengths, and the water heater is directly below the sink. The left side of the kitchen will have my Splendide washer/dryer and the fridger (a chest freezer converted to run as a fridge), then everything forward is a big living room.
Oh yes, one more thing. Get highway gearing and the biggest engine possible, then you'll have a comfortable long-distance cruiser that can tackle serious mountain grades. Cummins 5.9 engines and AT545 transmissions won't get you over Tioga Pass! School trip and activity buses that are used to take teams to away games, along with all their baggage and equipment, usually make good conversion buses.
10-16-2016, 10:21 PM
not so much. I'd bet they're 444E's.
BUY this one-
https://www.govdeals.com/index.cfm?f...=1&acctid=9245
SERIOUSLY! Buy it!
1997 Blue Bird TC2000 BUS, 8.3L L6 DIESEL.
rear engine
lower storage compartments
Engine 8.3 liter Cummins
mileage 95,206
Starts and Runs
No Cracked Glass
Normal Wear on interior
Minor Scratches Dings and Dents
Decals will be covered
This is a perfect opportunity to pick up a really REALLY great bus!
