Old 07-17-2011, 03:27 PM   #1
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
LP TANK
I have here an LP tank from a motorhome,looks to be about a 50 lb tank it has al the hock up still on it.Now this is one that hangs from the frame.It came from a 1996 35 ft home,this is for a perment mount,and no i don't have pictures,It was just pull from the unit.this will be a pick up only,, Asking $200.00 .the tank is in northern Ga.
pm me
thanks keith
keith is offline   Reply With Quote
Old 07-17-2011, 05:40 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: LP TANK
For those of you who do not know... these permanent mount RV tanks do not need to be re-certified. I would suggest a good cleaning, remove loose rust if needed and then paint it with one of the hammmered Rustoleum paints. I asked in NC about the rec-ertification of our 30 yo tank and the guys kinda giggled at me. They told me that the permanent mount RV tanks are exempt from the re-certification regs and that it was nationwide.
Fulltime since 2006
Old 07-17-2011, 06:13 PM   #3
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: LP TANK
thanks lornaschinske
Old 07-17-2011, 08:03 PM   #4
Stuff's Avatar
Re: LP TANK
every 10 years for tanks and every 5 years for vehical mounted tanks in sask an inspection is needed.
Old 07-23-2011, 04:23 AM   #5
Re: LP TANK
thanks for the info.
mikesaturday is offline   Reply With Quote
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 05:42 PM
gas tank to Black tank? turf Conversion General Discussions 19 07-28-2013 07:15 PM
LP TANK keith Classifieds | Buy, Sell, Swap 0 07-23-2011 04:41 PM
Which air tank to tap into ? rail_hauler Everything Else | General Skoolie Discussions 2 10-31-2006 09:06 PM
Would you use this tank? brentag Conversion General Discussions 3 08-04-2006 03:23 PM
