Old 05-09-2009, 09:04 PM   #1
lp tanks
Looking for rv lp tank i think they call them Manchester Tanks ,fit under the body, I went with a lp generator. and need one or two..
colliervilledave is offline   Reply With Quote
Old 05-09-2009, 10:18 PM   #2
frank-id's Avatar
RV Propane tanks
The cheapest place to find propane tanks are Craigs list, buy an old RV or place a wanted ad all over. The RV tanks are expensive and a special tank because of the OPD valve and remote fill, if ya need/want that feature. Even Ebay has these tanks but shipping is not cheap. Decide the tank location and size wanted before looking. I got my tank at a trucking company, who used same for a refrig compressor engine. Frank
Old 05-10-2009, 01:30 PM   #3
Re: lp tanks
Thanks Ill look on craigslist, and see what up..
Old 05-10-2009, 09:42 PM   #4
Re: lp tanks
be sure to look at the test date on the tank, if it doesn't have a current hydro test date, you can't get it filled untill it has been tested.
Old 05-16-2009, 02:07 AM   #5
swinada's Avatar
Re: lp tanks
underbody LP tanks do not have a testdate, only stand up cylinders do. However if you install an underbody tank and it is an older model, you might have to put a new 80% valve in. Older tanks only had a bleeding valve which you open when filling, as soon as you see white vapor exit the tank is at 80% and your supposed to stop filling. The new valves will automaticly shut off at 80%.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Holding tanks GreyEagle Plumbing, Water and Waste 19 06-22-2019 07:42 AM
Looking at some tanks rex_1_mn Plumbing, Water and Waste 3 09-26-2012 04:41 AM
four fuel tanks fishphart Alternative Fuels | Electric, Propane, Wood & Biofuels 0 09-15-2011 09:31 PM
Tanks a lot Jarlaxle Conversion General Discussions 2 09-03-2010 03:36 PM
Two tanks v. one? Branden Conversion General Discussions 5 06-03-2005 11:32 PM
