Old 05-22-2015, 01:04 PM   #1
Many parts available
Cord Caddy 12v powered cord reel, 50 amp service, cord and plug included
Allison MT654 5 speed, lockup torque converter - all mechanical, ideal replacement for a AT 545
Ring & pinion gears for a Rockwell SQHD differential; 3.55 and 5.29 available. I also have a carrier for the 5.29 gears
Leather swivel recliner.
Xantrex Freedom 458-20 inverter/charger.
Pictures available.
Make good offers, located in SE Wisconsin.
ScottT is offline   Reply With Quote
Old 05-23-2015, 01:58 PM   #2
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
What was the trans behind?
I'm hungry!
You Gotta Let Me Fly
Old 05-24-2015, 06:40 PM   #3
Trans
The trans was in front, it was a pusher.
Does it make a difference?
Thanks
Scott
Old 05-24-2015, 07:42 PM   #4
crazycal's Avatar
I meant what engine.
I'm hungry!
Old 05-28-2015, 05:58 AM   #5
Engine
Sorry.
903 Cummins.
Thanks
Old 05-28-2015, 11:10 AM   #6
crazycal's Avatar
Don't think that will work for me.
I'm hungry!
Old 05-29-2015, 07:48 AM   #7
SAE bellhousing
It's an SAE bellhousing, #2 I think.
Old 05-29-2015, 10:17 AM   #8
crazycal's Avatar
It's not just the bell housing size. They are set up internally for different engines based on rpms and gas or diesel.
I'm hungry!
Old 09-11-2015, 07:37 PM   #9
Do you still have the Xantrex Freedom?
zedster is offline   Reply With Quote
Old 09-11-2015, 08:25 PM   #10
Engine: 190hp 5.9 Cummins
Thanks
Scott
No, the transmission used on rear pushers are the same as the front engine buses.
The rear differential or axle is where the difference is. The rear engine buses use a revers ring gear, and a flipped center pumpkin.
