Old 01-24-2013, 09:32 PM   #1
frank-id's Avatar
Need a Cummins PT Pump
My Cummins PT Pump is done and a replacement needed. Engine is a 743/855 engine. Frank.....frank.id.crownatgmail.com
Old 01-26-2013, 08:32 PM   #2
frank-id's Avatar
Re: Need a Cummins PT Pump
bump
Old 01-29-2013, 05:33 PM   #3
frank-id's Avatar
Cummins PT Pump
PT Pumps are available. Most pumps are for sale at about $200, Cummins sells a rebuilt pump for about $450.
These pumps are not difficult to reseal/repair. Ordinarily the pumps need little service unless some engine changes happen. One basic change in a pump is more power wanted. Any upgrade in the turbo sometimes requires a pump change. With little knowledge, the engine will make lots of smoke and not much more power. Changing a pump from one engine that the same, requires no pump work. Economy is mostly controlled by the driver. Few truck shops
work on old engines. Frank
Electric to mechanical lift pump 5.9 Cummins nat_ster Cummins Drivetrain 5 08-27-2015 09:29 AM
Centrifugal Pump Xtevan Alternative Fuels | Electric, Propane, Wood & Biofuels 0 04-04-2008 01:48 PM
Use of Cummins 5.9 manual priming pump? Elliot Naess Everything Else | General Skoolie Discussions 6 05-17-2007 10:16 AM
Looking for any information about Cummins PT Pump frank-id Everything Else | General Skoolie Discussions 1 04-11-2007 07:14 PM
blue bird cummins pump? The Wanderer Conversion General Discussions 9 02-28-2007 01:55 AM
