05-09-2017, 10:46 PM
#2281
These are the 19.5s. I checked yesterday to see how much room there was between the top of the tire and the floor of the bus. About 2" clearance even with those smaller wheels.
Right, but what size tires? I need a frame of reference for how fast the rear end gearing actually is.
05-09-2017, 11:02 PM
#2282
245 70r 19.5
Robin
Nobody's Business
05-09-2017, 11:10 PM
#2283
Those are about 33" tall.
With 3.54's, that puts it turning about 2,450 rpm at 65 mph.
Perfectly acceptable for a 6BT. Redline has you running 83.
05-10-2017, 12:05 AM
#2284
It doesn't like to do 65. This bus likes to pull a flat 60. Lots of personality in this Bird. I'm going to be the slow boat in the states that have higher speed limits, and I can live with that. More time to see the sites. I'm not going anywhere fast.
It's getting better after a few longer road trips. It was so gummed up. Maybe my speed will improve.
Robin
Nobody's Business
05-10-2017, 04:23 AM
#2285
My red bus has 225/70/19.5 with 3.54 gears , I get 65-70 easily in it but I think the small wheels ride harsher
Christopher
05-10-2017, 04:49 AM
#2286
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Rameses: You definitely won that one!
M
05-10-2017, 05:29 AM
#2287
That one didn't have the flasher covers (eyebrows), and it's rare to see the TC1000 with a front WC lift.
I didn't realize they use a different front cap either. I think it looks like they used two back end caps.
Did you notice that 3.54 rear axle on the data plate?
3.54 is common with 19.5's on a TC.
05-10-2017, 07:28 AM
#2288
Oh, I didn't realize you were running a 3.54 too.
05-10-2017, 07:49 AM
#2289
id like to find a taller tire... is there a chart somewhere that tells me.. with a certain Accuride rim number what tires i can run without my duals touching?
05-10-2017, 10:08 AM
#2290
Chassis: Carpenter
Engine: d466 mechanical
Originally Posted by tobeamiss
It is but they didn't take down the ceiling and insulate.
You don't have to take down the ceiling to re-insulate up there. everywhere else has 2'' of r19 board. The ceiling has new batting.
"Thermal Break" isn't a big deal when the roof is insulated and painted to reflect sun. I got down to 66 degrees off one AC in 95 degree florida weather, and I stayed warm in 31 degree weather in Texas. If that isn't proof the ceiling theory isn't a major factor I don't know what is.
Nowhere Fast - Sarasota, Florida
05-10-2017, 10:12 AM
#2291
maybe every bus is different? my red bus has factory A/C and even in the hot sun the ceiling gets warm but not blazing hot to the touch...
my carpenter bus was built without A/C, and I added it.. the moment the sun comes out that ceiling gets Blasted hot to the touch...
the red bus has a regular white paint ceiling, the carpenter has a regular paint very light beige ceiling...
05-10-2017, 12:50 PM
#2292
When Dave and I tested different paint colors with an IR heat sensor, white was ten degrees cooler than any other color, even light colors.
05-10-2017, 06:41 PM
#2293
Fixer upper... ****'ll buff out.
https://ocala.craigslist.org/rvs/6106099164.html
Too bad folks leave buses sitting till they're virtually no good. I'd love a nice, running, clean one of these!
05-10-2017, 07:18 PM
#2294
The add says it was underwater. So that's one of them submersible buses.
Robin
Nobody's Business
05-10-2017, 07:28 PM
#2295
Damn it. Why can't that be closer to me?
That thing's got $1,200 worth of wheels on it.
05-10-2017, 07:34 PM
#2296
It's basically free too. They did say they'd be willing to take something in trade.
Can you imagine what the inside looks like after being flooded. What a project.
Robin
Nobody's Business
05-10-2017, 07:37 PM
#2297
Awsome that it's working out for you.
I'm glad I took mine down though because I found alot of mold on the existing insulation and some rust on a couple of the panels.
#2298
Somewhere out there is a guy or gal in need of some or all of that glass, too.
05-10-2017, 11:00 PM
#2299
Chassis: E-450
Engine: 7.3 Turbo
How does a bus that big end up "under water at one point"? I can see in water, but under... someone made a big mistake.
05-10-2017, 11:03 PM
#2300
Being in Florida, a hurricane might've been involved.
