06-02-2017, 06:28 PM
#2381
Wow.
An overdrive with a 3.73 rear end. That thing'll move!
06-02-2017, 07:09 PM
#2382
Originally Posted by Rameses
Wow.
The 6v92 will definitely help it move right along, too!
06-02-2017, 07:52 PM
#2383
Wow.
"Fuller RT11610 transmission "
I am pretty sure that is not an overdrive. Regardless, 1:1 10th gear, 3.73 rear and 11R22.5 tires and a 2350 RPM governor setting would yield 79mph top speed.
I want it.....
06-02-2017, 08:13 PM
#2384
I want it.....
Yeah, I saw that they said that, but then they posted a picture of the shift pattern plate which says it's an RTO.
06-02-2017, 09:30 PM
#2385
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
That's a sweet bus
06-03-2017, 10:47 AM
#2386
I missed that in the picture. I wonder which is correct, the pic or the text?
If it is an RTO then top speed, if it will pull to redline, would be around 93mph.... Scary....
06-03-2017, 11:48 AM
#2387
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
06-03-2017, 12:29 PM
#2388
Damn. I REALLY want that bus.
06-03-2017, 04:45 PM
#2389
I'd trust the pic over the seller's description.
Unfortunately, that also means it might not actually have a 3.73 rear end.
As always, buyer beware.
06-03-2017, 06:37 PM
#2390
Engine: TE 444
Rated Cap: 12
That is one strange backwards shift pattern though
06-03-2017, 06:46 PM
#2391
Yeah, that's because the transmission's mounted backwards since it's a rear engine.
How long do you think it'd take to get used to shifting like that?
I'd imagine the learning curve gets pretty steep after you try to shift from first to reverse a couple times.
06-03-2017, 08:37 PM
#2392
Doesn't seem too bad. Anyone wanna drive this from CA for me?
06-04-2017, 02:26 AM
#2393
You buy the plane tickets, and pay for the fuel, and I'll drive it with no charge for my time.
06-04-2017, 05:39 AM
#2394
id love to drive something like that across the country... though not in summer! going across arizona and texas with no air-conditioning in June.. LOL
what a GREAT looking bus that is though... ill bet that goes for at least 8K in the end.
06-04-2017, 05:58 AM
#2395
Naw, man- the GOOD ones don't go for much. I bet it stays under $4k.
Folks only buy the buses we warn them against.
06-04-2017, 05:59 AM
#2396
I'll check with the minister of finance and get back to you.
If it weren't the middle of summer and if I hadn't just bought a bunch of tools I may have had a shot. I'll see if I can pull it off, though.
06-04-2017, 04:25 PM
#2397
Engine: TE 444
Rated Cap: 12
Lost all my overtime, I can't buy it
06-04-2017, 06:44 PM
#2398
Coachwork: Amtran Genesis
Don't know if this one has been posted but I don't remember seeing it
https://goldcountry.craigslist.org/cto/6159712926.html
06-04-2017, 06:47 PM
#2399
Wanderlodge
06-04-2017, 07:12 PM
#2400
That '74 at $5k, with the swapped out yellow steel wheels and less than 40% tires, seems odd. You show and item the way you're going to sell it. He's keeping the shiny wheels and putting on tires less than 40%. First stop at a tire shop? I like this bus but...
The Wanderlodge is nice and still a decent deal, but expensive in my book.
Robin
Nobody's Business
