08-30-2017, 01:18 AM
#2761
Engine: gasser probably
Starting Bid: $15,000.00
"Paid $32,000 for engine work in April 2016, see pictures for repair and replacement services."
https://www.govdeals.com/index.cfm?f...20&acctid=9260
I'm a noob, but I dont know about that starting bid. . .
I guess a new engine could cost that much, idk.
08-30-2017, 02:40 AM
#2762
I have not idea as to what they had done to it but for $32K it must have been gold plated. A new out of the box replacement engine and transmission installed shouldn't cost much more than about $15K-$20K.
I think they are going to be sitting on the bus for a while with a starting price that high. It just isn't worth that much. Even with a lot of engine work. Unless it comes with a new warranty that has five more years and/or 100K miles to go.
08-30-2017, 02:42 AM
#2763
Originally Posted by jordan76
There's a couple of these on Public Surplus at the moment. This is the length and internal height I'm looking for, I was hoping some of the more knowledgeable folks could weigh in on the engine / transmission combo and whether these are a decent value with a $4500 starting price (and an even higher reserve). Thanks!
http://www.publicsurplus.com/sms/auc...16&trackId=165
That looks like an okay bus but it does have the Cat C7 engine. The C7 engines along with the prior 3116 and 3126 can be money pits
I would not pay much more than the current bid.
08-30-2017, 02:48 AM
#2764
Originally Posted by Kubla
It looks a bit down and the heels parked out in the tall grass with mud all over the wheels.
But as long as it doesn't have any rust that could be a really good bus for someone.
It has the 9" windows and does not have a flat floor.
But it does have the DT466, tinted glass, and a white roof.
The black screens in the lower skirt on the driver's side suggests it has A/C.
It would still be a good deal at $4K in my estimation. As long as it doesn't have any rust.
If there is any rust it is about topped out.
08-30-2017, 05:07 AM
#2765
I wouldn't pay half that for one of those.
Too new to be any fun to work on. Expensive to maintain.
08-30-2017, 07:09 AM
#2766
a forum member last year roasted a navistar VT-365 engine. and was quoted a total of $25k to install a reman engine.. the VT-365 was one of the "cheap" ones.... so i could believe 32k for a Cat.
09-01-2017, 05:54 AM
#2767
The starting price on that one is high but this other one looks like a good deal with under 14k miles and most conversion work already done. Gen set, Jack's and tanks onboard too.
https://www.govdeals.com/index.cfm?f...k3rKcavJo.link
09-01-2017, 11:02 AM
#2769
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Originally Posted by Huskerbus
Honestly, it's a pretty good motor from what I have heard, but with the disclaimer that CAT is expensive. Check out adept ape on YouTube. He does all things CAT.
09-01-2017, 11:20 AM
#2770
Engine: 8.3 Cummins, 643
I'm not sure I have seen a bus that size with an engine that big, not saying it's incorrect but I would probably go look at the bus myself or at least call the maintenance personnel to confirm. I am not a bus expert but have looked at enough that this seems a little out of place... I'm sure someone will correct me if I'm way out of line
09-01-2017, 11:24 AM
#2771
Rated Cap: 31 w/4 wheel chair spots
I couldn't agree more. However, I did a VIN decode, and that is precisely what it came back as. 1000+ ft-lbs in a bus that size aught to be fun!
09-01-2017, 11:36 AM
#2772
Hills should present 0 issues if it is running correctly, might look at maintenance cost on that engine. Seems like the bigger they are the more expensive, generally....
09-01-2017, 01:12 PM
#2773
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
they said this?
Q: can you clarify engine and trans please 10.3 was not an option for this bus (9/1/17 8:59 AM)
A: 6.2 Cummins (9/1/17 11:45 AM)
09-01-2017, 02:27 PM
#2774
Interesting sounds like they really know there equipment well.
09-01-2017, 04:39 PM
#2775
IDK how many were sold, if any, but the legendary Cat 3406 was apparently an option on my 3800 Navistar.
Never seen a C10 in a bus. Would be cool, but expensive.
09-01-2017, 05:41 PM
#2776
here is a cool bus:
i don't think i understand what it is yet. it looks like a rear engine 5.9, with a rear door. maybe its a mid engine? i cant make it out. check it out.
BigIron
09-01-2017, 06:02 PM
#2777
[QUOTE=turf;222056]here is a cool bus:
I think your right re with a back door, cool setup
09-01-2017, 07:49 PM
#2778
Engine: TE 444
Rated Cap: 12
it is rear engine with AC, floor is higher than normal it looks like
09-05-2017, 09:57 PM
#2779
Year: 96
Engine: Dt 466
Dont think this has been on here, but I remember someone talking about a crazy roof raise. Here is a 40" roof raise no windows.
https://houston.craigslist.org/cto/d...262589269.html
09-05-2017, 10:17 PM
#2780
Originally Posted by Thunder
THose uprights don't look straight. Maybe why they quit?
