02-08-2018, 12:35 PM
#3461
Originally Posted by cdelvecchio
How do you know it has a high ceiling? I have a hard time finding actual dimensions of buses I'm looking at. Is it just a known fact for the Genesis buses?
Thanks for your two cents. I'm in CA and there seems to be limited selection in my area right now. I want to avoid traveling far for a pick up.
You can tell it is a high roof model because it has the 12" windows and not the 9" windows. The clue is the top line of the windows is above the top of the driver's side window and the top of the service door.
Once AmTrans became IC the IC buses got a lot of options as standard because it was just easier to build all of the buses one way instead of having choices. As a consequence starting in about 2001 all of the IC RE buses got the high roof and starting about 2004 all of the IC CE buses got the high roof standard.
As far as the 2007 Thomas, I would stay away from a C2 even if it was the only bus for sale anywhere. All of the C2's have electrical gremlins due in large part to the fact all of them have been multiplexed. The older ones are worse than the newer ones. In addition, a 2007 engine will be smogged which has some additional problems that make running a bus difficult.
02-08-2018, 12:49 PM
#3462
So the other bus I'm looking at is... https://www.govdeals.com/index.cfm?f...35&acctid=8151 ...
A 2007 Saf T Liner C2 bus, 48 passenger. It more costly, however it seems like a great deal and better for road tripping vs. the Genesis? Thoughts/experience with the C2 buses? Also, my husband wants a shorter bus than 30 ft. so that is strike one for the Genesis :P
a 2007? I'd pass! Not a better deal at all. The emissions garbage on that engine will cost thousands to maintain.
02-08-2018, 12:50 PM
#3463
My 2004 CE300 has the low ceiling, Cowlitz.
02-08-2018, 02:15 PM
#3464
Coachwork: Amtran Genesis
I noticed these sites have very little information regarding service history and I definitely cannot go see the bus in person before I bid.... whats your experience with purchasing from the auctions? any help is appreciated!
The service history of this bus will not come with it. You can however ask them to email you a copy to look at. They have always done that for me in the past.
Copied from the site:
what size engine is it. does the lift work properly? do you have service records for the bus?
Answer
The engine is an International DT466.
Service records can be viewed however not included with the bus.
(Answered: Feb 2, 2018 9:31:42 AM PST )
Question #2
Feb 5, 2018 8:15:43 PM PST
do you know the length of the bus.
Answer
This bus is 30' .
(Answered: Feb 8, 2018 9:51:46 AM PST
02-08-2018, 02:23 PM
#3465
Originally Posted by brokedown
Maybe Minus: Wheelchair lift is in the middle of the bus!
Actually the lift is at the rear on the passenger side.
02-08-2018, 03:20 PM
#3466
I had a bus with the midship chair lift. I got tired of climbing over motorcycles in the middle of the bus to get to the rear door. The only thing worse would be the front mounted chair lift.
Robin
Nobody's Business
02-08-2018, 04:04 PM
#3467
Engine: Dt466e
Rated Cap: 71
i just checkout out 5 2004 ce200, all with low ceiling
i think 05 they switched motors, so maybe thats when they did the high ceilings?
02-08-2018, 04:57 PM
#3468
Chassis: Saf-T-Liner MVP ER
You can also tell it's a high ceiling because that was mandated from 2006.
02-08-2018, 09:13 PM
#3469
The bus in question is a 95, IIRC.
But thanks for confirming the year of the headroom change. Guess the extra headroom is nice when you're broke down on the side of the road due to complex emissions garbage and an engine made of unobtanium.
02-08-2018, 09:19 PM
#3470
So that wouldn't be nice.
The good news is that Thomas shipped an awful lot of pre-emissions Saf-T-Liners with 77" headroom.
I only have one of them, so there are plenty left for everyone else
ps ... There is an easy "tell". The roof has a distinct rise right behind the driving position. It's very easy to see.
02-08-2018, 10:18 PM
#3471
Chassis: TC2000 (3904 RE)
Engine: Cummins 8.3TA
One of those, between 35 and 39 feet long, with a rear engine and underbelly storage is exactly what I'm looking for.
Good to know to look for the roof bump. That will help. Thanks!
Sent from my Nexus 7 using Tapatalk
02-08-2018, 10:20 PM
#3472
This 95 is high headroom. Easy to spot with the tall windows. Short wheelbase AmTran Genesis.
02-09-2018, 06:39 AM
#3473
02-09-2018, 06:41 AM
#3474
Originally Posted by 45acp
Their church probably doesn't "utilize this bus" due to the extreme repair/maintenance bills. Seriously.
02-09-2018, 10:18 AM
#3475
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
IDK about that bus, but LOVE that garage !
02-09-2018, 11:42 AM
#3476
As someone who has worked hard to keep a church transportation ministry operating I can tell you that there are a lot of challenges involved. High on the list is finding and keeping qualified CDL drivers available to drive the bus.
I would suggest that less than 10K miles in ten years means they probably didn't need to purchase a $90K bus to meet their needs. I suggest it probably cost $90K because that A/C system is about a $10K option on top of a bus that is already highly spe'c'ed.
I would also suggest that the fact it is a 2007 model bus means it would require the church to install an Electronic Logging Device under certain conditions. All of our church buses are pre-2000 and all mechanical so they are exempt from the ELD mandate.
And I would also agree that as an early emissions model the bus is probably a garage queen. And now that it is out of warranty it is probably a sucking hole for cash.
As I have worked with churches who have wanted to start a transportation ministry I have discussed with them the actual costs of owning vs. renting/leasing vs. chartering buses. One of the number one things I try to disabuse them of is the idea that their church can afford to own a motorcoach. Unless they anticipate traveling more than 10K miles per month no church can afford to own a motorcoach.
And unless they are really affluent purchasing a brand new bus is probably not being a good steward. In this case that is patently clear.
Our church doesn't rack up a lot of miles per year per bus but each bus goes a lot more than 1K miles per year.
02-09-2018, 06:18 PM
#3477
$900 Shortie
Needs a carb rebuild but might be worth it to someone wanting a shortie.
https://reading.craigslist.org/cto/d...454882137.html
02-10-2018, 03:52 PM
#3478
30 ft Genesis
So is anybody here bidding on this short Genesis that was posted earlier? There is only a couple of hours left on it. If nobody from here is bidding then I will probably put in a bid myself. Would not mind having matching long and short Genesis busses in my yard.
https://www.publicsurplus.com/sms/au...3D&auc=2022935
02-10-2018, 08:06 PM
#3479
1964 Chevy Short bus
64 Chevy short bus body and frame are solid seats and glass all there. Yard drives 6 cyl manual and has a Cummins 24 valve and Allison trans to go in it.
$2,500. Maine craigslist Rockport Maine
02-10-2018, 08:44 PM
#3480
If I had any way to get it home I'd buy it.
Next week some newb will come to this forum saying they've been searching for THIS bus for a year and can't find one...
Was bought by "moki"... A former forum member who flips clean western buses.
