06-11-2018, 06:25 PM
#3901
top one is a Superior S-series.. a rare bus!! they didnt make many of them.. if it didnt have missing windows and holes punched in the roof id have been all over that...
06-11-2018, 08:52 PM
#3902
The first bus is an IHC/Loadstar with a Superior body. Most likely engine is an SV345 gas engine with a 5-speed manual. It is a lighter duty model with the 5-lug disc wheel. GVWR is probably about 20K.
No picture would worry me.
The last bus is a Ford E-450/Thomas bus. It is going to be heavy and not have a very large net payload capacity. GVWR is most likely 14,000 lbs. and the empty weight without seats is going to be over 11,000 lbs. and probably not too far from 12,000 lbs.
06-14-2018, 01:38 AM
#3904
Coachwork: None yet
Originally Posted by Kubla
Our local school district is still running one of those tag axle Crowns. Cool old rig.
06-14-2018, 03:09 AM
#3905
The vast majority of Crown tandems didn't have a tag axle. Almost all were tandem drive with a differential lock to make both the front and rear axle turn together. Without the diff lock you could end up with just one wheel spinning.
06-14-2018, 03:21 AM
#3906
Originally Posted by magnakansas
The 1980 Ford Blue Bird is going to be a slow gas hog. The Ford gas V-8's were all pokey unless you got the big ones and then they were really thirsty. The 331/361/391 got in the 5-7 MPG with an automatic. The 429 and 534 were in the 2-4 MPG range.
The 1987 gas mini that needs some work would be expensive if it were free. Notice the roof line--it is high over the center aisle but chopped down over the seats. A bus with a roof like that would have no room for any over the window cabinets. And raising a roof like that is a non-starter for so many reasons it isn't worth considering.
The 1975 Superior bus on a P-30 chassis might not be a bad deal as long as it runs okay. It will have all of the problems every other bus on a P-30 chassis has--too much bus for the truck underneath.
The 1990 Ford Wayne bus appears to have a Brazilian Ford diesel engine and most likely it has Girling brakes--a duo combination that is not the best.
The 2010 mini diesel bus has over 300K miles on it. That bus is going to be worn out with the body starting to have stress cracks and leaks from the seams. It will also need DEF to run. A bus with that many miles and perimeter seating is not going to be a big seller. The asking price is about 3x of what it is worth.
06-14-2018, 12:15 PM
#3907
84 Crown WA state
06-14-2018, 12:16 PM
#3908
Coachwork: None yet
Terminology mistake on my part, thanks. Dual rear axles, I never looked underneath it to see if the second one was driven. I'll bet that makes for some fun maintenance and rolling efficiency.
06-14-2018, 01:08 PM
#3910
Originally Posted by dan-fox
I'd be leery of anyone selling 4 different buses but use the same pics, what does the one I'm interested in actually look like? There was one listing where the guy took a pic of the back but held his hand up so you can't read the plate. I am still trying to figure out why people conceal the plate on their for sale vehicle. I can't legally get any info from his tag, so I don't understand that. If you're trying to keep the vehicle from getting stolen, what prevents me from calling you with interest and asking where can I see this? And then stealing it later?
To me, that's a $5k bus. You might talk them down from $15 to $10 and you'll still be paying too much.
06-14-2018, 02:23 PM
#3911
They seem to buy up as many AZ auctions as they can and then sell them for full retail. There's one or more of those dealers in almost every state.
LOL one lease payment covers what they have in the bus!
06-14-2018, 03:36 PM
#3912
Engine: Cummins 8.3
I called and they're claiming that they're worth 30-35K due to the particulate filter. Hope that saves some time for others.
06-14-2018, 07:54 PM
#3913
Engine: TE 444
Rated Cap: 12
06-15-2018, 08:51 PM
#3914
Engine: 8.3 Cummins ISC
Rated Cap: 75
444E in a pusher? No thanks. There’s a reason why every bus dealer is sitting on them
06-23-2018, 05:59 PM
#3915
Activity bus
https://www.govdeals.com/index.cfm?fa=Main.Item&itemid=1145&acctid=686
06-23-2018, 07:24 PM
#3916
Hello WIBlueBird. Just curious about the issues with this engine in a pusher. I’m pretty new to all of this, and still sucking in as much info as I can, so I’d love to understand this.
06-23-2018, 08:16 PM
#3917
those miles are a deal breaker.
06-26-2018, 10:28 AM
#3918
Winning bid was $7500
06-26-2018, 11:35 AM
#3919
That's a tad higher than I thought it would go for! Looked like an easy starting point for conversion, and there seemed to be quite a lot of interest. Thanks for the update.
06-26-2018, 01:41 PM
#3920
Coachwork: American Cargo 14'L x 7'8"W x 7'H Box
Chassis: Ford E350 Cutaway
Rated Cap: 11500 lbs
Care to elaborate?
Too little power? Cooling issues? Access?
