01-28-2019, 08:34 PM
#4381
Coachwork: 1991 bluebird
Yea, I want to see if I can find one locally that I can do a hands on look at. My build is going to be unique. Not that I don't think that a transit bus wouldn't work. The thought of having it an actual 8 feet inside is nice. That extra 6-8 inches makes a big dif when you're trying to squeeze all this stuff in. What I want to know about is the step up difference in the back half of the bus. 2 full size doors is really nice. Wonder if the wheel chair ramp could be moved to the back door. I believe they're wide enough to get a motorcycle through.
01-28-2019, 11:12 PM
#4382
Can't say I have ever seen (or heard of) any bus with 8 feet clear on the inside unless it's had a roof raise (?) Anyone else?
01-28-2019, 11:23 PM
#4383
Chassis: Vista 3600
Engine: DT466E / AT545
Hopefully they're not bound to the 45-50 top speed a lot of NC schools seem to have.
Hey now, I can get mine to 55 going downhill with a heavy tailwind!
01-29-2019, 01:21 AM
#4384
Some of the low floor heavy duty transit buses will have headroom approaching 8' in the low floor section. This due in large part to the fact the headroom behind the rear axle is still over 6' of headroom which is all done with a roof with no humps.
01-29-2019, 10:28 AM
#4385
Year: 98
That is correct. Mine is 8ft in the front and 6 ft8 in the back with 2" floor heating .
Later j
01-29-2019, 11:15 AM
#4386
No bids yet on the Thomas FE's with 230hp mechanical 5.9 and MD3060.
I think that they are all under 200k miles..
https://www.publicsurplus.com/sms/li...c7eb2192eb3b4f
01-29-2019, 11:33 AM
#4387
Those are neat. i didn't know you could mate a 3060 to a mechanical engine.
#4388
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
First one I looked at is a front engine
01-29-2019, 12:16 PM
#4389
I wish they were closer. I'd pop for one.
01-29-2019, 12:57 PM
#4390
They all are. Sorry for the typo.....
01-29-2019, 12:59 PM
#4391
Road Trip!!
01-29-2019, 01:03 PM
#4392
As best I understand it, the MD-3060 can be installed behind a mechanical engine with the addition of a TPS.
I bet Christopher has the definitive answer
01-29-2019, 01:57 PM
#4393
Chassis: Bluebird
Rated Cap: 72 pax
Ah, ok. Figured they were a mixed bag. Those seem to be about to go at a decent price.. hopefully someone out west picks one up.
01-31-2019, 01:14 AM
#4394
I'm sure someone here would drive it to ya.
01-31-2019, 03:44 AM
#4395
The first 3060s did exactly what Steve is talking of.. however no 6th gear unlock on those as nearly no one will touch the WTEC II TCM.. diagnostics is limited, so best to make sure your gearing is good before you buy it.
01-31-2019, 06:38 AM
#4396
Good to know.
Still its a really stout tansmission with OD. I think you double OD folks are getting spoiled!
01-31-2019, 07:03 AM
#4397
Good to know.
im not saying its not a good option, but gears are still important.. an overdrive trans with 7.17 gears itsnt goingto be fast.. the guys unlocking 6th are doing it because their busses are often geared where they are at the top of their RPM range.. 5 speed is a perfectly fine option.. in fact I dont even use my 6th gear because it runs my RPM too low till I regear..
but you'll have trouble getting 6th unlocked on the old WTEC II TCMs.. no one wants to touch them.
01-31-2019, 07:05 AM
#4398
Gearing is always important
01-31-2019, 07:15 AM
#4399
Final drive is the most important.. how much pavement is pushed by 1 revolution of the engine... if you know that then you can calculate evcerything else..
01-31-2019, 07:22 AM
#4400
Yep, that's how I figured out I've got even higher gearing than the bus was built with. Using the #'s I've figured it at 3.42:1!
This bus is kind of a unicorn. 6" lift, low miles, insane highway gears...
