Old 02-04-2020, 11:32 AM   #5201
Originally Posted by Beachvbguy View Post
I am curious about the mileage. Listing says 181k. Odometer says 81k and the note under it says speedometer replaced at 31k. Does the bus have 112k or 181k?
Nice drive train.
Old 02-04-2020, 02:36 PM   #5202
Chassis: Ford e450
Engine: 7.3 Powerstroke
A couple NE marketplace shortie finds:
https://www.facebook.com/marketplace...ssenger_banner
awilder is offline   Reply With Quote
Old 02-04-2020, 10:34 PM   #5203
Chassis: GMC 3500 Thomas
Engine: 6.0 L GAS
A nice medium sized bus in Ontario Canada :
https://www.kijiji.ca/v-rv-motorhome...ale/1485548464
skidfrog is offline   Reply With Quote
Old 02-05-2020, 01:47 AM   #5204
I would double check what engine it has because most of the Ford chassis buses of that vintage that were running diesel engines were running Brazilian Ford Diesels. IIRC, they came in 5.9L and 6.6L.
Also, if it has the Girling brakes I would pass on this bus. They are good brakes you just can't easily get parts and pieces to fix them anymore.
Old 02-05-2020, 09:17 AM   #5205
https://www.govdeals.com/index.cfm?f...4&acctid=16909
thoughts on this bus?
appman55 is offline   Reply With Quote
Old 02-05-2020, 10:25 AM   #5206
Any thoughts on this bus?
Old 02-06-2020, 07:16 AM   #5207
Chassis: Saf-T-Liner
Engine: MBE 906 Mercedes Benz Diesel
What about this shortie?
https://www.publicsurplus.com/sms/au...ew?auc=2522246
Beachvbguy is offline   Reply With Quote
Old 02-06-2020, 10:09 AM   #5208
ACamper's Avatar
Free 1960s School bus with RV conversion NO TITLE
https://denver.craigslist.org/rvs/d/...069662569.html
ACamper is offline   Reply With Quote
Old 02-06-2020, 10:13 AM   #5209
The 6.6 Duramax has a pretty good reputation.. In the pickups they put the Allison 1000 behind it. I have heard that they put a lesser transmission in the van chassis. I have no first hand experience with the GM's just passing on something that I was told.
Regarding cutaways : I bought one a couple of years ago and really did not like the engine access. I griped about how hard it was to work on while talking with the service manager from a local utility company. He explained to me that they found it much easier to work on their cutaways if they lifted the cab off of the chassis.
Good luck.
Old 02-06-2020, 10:15 AM   #5210
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
Good luck.
On the cutaways you get decent access by removing the interior doghouse. A lot of the engine actually sits INSIDE the van cab but I agree, access compared to a convetional full size is pretty bad.
The Duramaxes in the vans are detuned, there is no intercooler and they are turned way down. I think they make something like 65% the power of the trucks.
Old 02-06-2020, 10:30 AM   #5211
The basic problem with all Type 'A' buses is there is a lot more bus on top than there is truck underneath to support it.
With a GVWR of just over 12,000, I doubt you will have much more than 3,000 net payload available, it that much.
A Type 'C' of the same basic passenger capacity will have probably double the amount of net payload available.
Old 02-06-2020, 10:52 AM   #5212
Your idea of "decen" may be different than mine I don't have a lot of patience with machines that make me cuss and bleed.
Do you know what transmission they used on the cutaways?
Random bit: I saw a 1000hp (so they said) 6.6 Duramax in a '67 or '68 Chevelle. I want one
Old 02-06-2020, 11:54 AM   #5213
Nice drive train.
Question and answer shows it has 181K.
Old 02-06-2020, 12:11 PM   #5214
Engine: International DT466
Nice drive train.
I asked the seller that question hoping for a different answer. We're looking for something that'll go about 120K over ten years without needing a replacement, so 181K could work for us...but doesn't that note about the speedometer change make 181K feel a bit off, even with the official answer?
keithgugliotto is offline   Reply With Quote
Old 02-06-2020, 12:43 PM   #5215
WIbluebird's Avatar
Rated Cap: 75
https://www.publicsurplus.com/sms/au...ew?auc=2526667
nice clean AZ bus, not sure what they mean by 5.29 Cummins though
I thought '99 was the first year for the A3 body style but this is an older All American. Possibly a <1998.
https://www.publicsurplus.com/sms/au...ew?auc=2522968
Nice Utah bus with an exhaust brake. Can't tell if that's an MBE or a Cummins in the engine bay though.
Old 02-07-2020, 01:14 AM   #5216
Edit: Never mind. I misunderstood the reply.
Old 02-07-2020, 01:59 AM   #5217
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
I saw that listing, I'm pretty sure that it's a Cummins 5.9 24v. I wonder how it fairs in that large of a bus.
An MBE should have a very visible oil filter on the upper front left of the engine, just like this one in a 04 HDX.
Truthseeker4449 is offline   Reply With Quote
Old 02-07-2020, 08:19 AM   #5218
WIbluebird's Avatar
Rated Cap: 75
Wasn't 2007 the first year for 6.7? Also that does look a tad large to be a 6.7. Maybe it's an ISC?
Old 02-07-2020, 10:57 AM   #5219
Chassis: MVP ER
Engine: CAT 3126
They just updated the listing, it's a 8.3. I'll have to save some of these pictures for future reference, that would be awesome to find 8.3 in something. Sadly this one is already out of my price range and I'm more wanting to pickup a parts bus with 3126 with AC in it.
I can't speak for what year the 6.7 came out and they feel big enough in the Freightliners at work.
Old 02-07-2020, 11:18 AM   #5220
WIbluebird's Avatar
Rated Cap: 75
The 6.7s are very nice for what they are. I expect them to become the preferred engine among skoolies in another decade when they become prevalent on the used market.
The 8.3 ISC is on a whole nother level though. My Bluebird will climb the big hills without even breaking a sweat at 55 mph whereas the buses at work will be screaming in 2nd and barely getting 30 mph on the same hill.
