04-28-2016, 03:14 PM
#352
Chassis: International S3800
Originally Posted by skoolie_n00bie
that first one looks to be in good shape!
the second one was called mini-birds..
definitely was a school bus
04-28-2016, 03:38 PM
#353
In comparison, last October my '97 Bluebird TC1000 was $2,600 with 167K on it.
This first one appears to be basically the same as my current 26'r, but with the city bus setup and windows. I like white buses and that looks good from what I can see. It also looks like someone is trying to double their investment in the bus or maybe it's a dealer. I'd love to have it but that's too rich for my blood.
That second one; Can you imagine all the hours that went into detailing that paint job? That body style reminds me of Grumman vans, only with windows and seats. Something like that would make a good spare bedroom for when family visits, especially if it was free.
You're not finding anything on Public Surplus?
04-28-2016, 03:53 PM
#354
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
The $$$ of the 1st one was what jumped at me, too...but i do like the style and color.
2nd bus..i'm starting to like that body style! i see these a lot in MDC, probably because roadways are too narrow for larger busses!
Nothing interested me on public surplus from FL...passing time viewing entries from other states...yearning to work on mine...
04-28-2016, 03:54 PM
#355
Coachwork: IC
Chassis: CE300
Rated Cap: 32
time out purely by calendar?? or time out as in they may not have a lot of miles but have become unsafe by caracking, rotting, etc??
do you really throw a tire out because its just "old" or only when it shows signs of damage?
On something like a bus, the date codes on your tires become much more important than a car.
http://www.cbs46.com/story/27175273/...hool-bus-tires
adding weight to a bus doesn't help things any.
04-28-2016, 07:27 PM
#356
the ionly reason I ask is because usually as a tire ages physical and visible signs will shoew that the tire is getting unsafe...
the steel belts arent goingto rust encased in rubber.. thoiugh they might if there are deep cracks in the tire and the belts show - visible aging..
my last bus the tires were old but showed no signs of cracking or dry rotting because IO kept them treated and the bus was stored indoors away from the harmful UV that often is the demise of rubber...
are you saying there was likely hidden non visible aging to my tire that caused it to be unsafe ? they were past their code but looked and drove like new...
04-28-2016, 08:38 PM
#357
If you're being inspected under the school bus rules, the requirements are considerably more stringent than the general public is used to. Generally speaking these truck tires are quite high quality and we sure aren't going to use them like a trucker would. The will very likely age out before we're even half way through them. It's a fact.
I have driven farm trucks with heavy loads on old cracked tires that were visibly way beyond their years of service. It was low speeds but hauling large loads. I wouldn't have believed it if I hadn't been there.
Point is if my tires are timed out and I still have 80% of the tread remaining and no apparent visible damage, I plan to continue using those tires. The tire shops are not shy about telling you when you need to get new tires, or when you can use them beyond the normal life if they are still in good condition. Perhaps I will get two new steer tires and continue running the older tires on the rear. I don't know yet. Check back in 8 years.
04-28-2016, 08:42 PM
#358
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I believe commercial tires are replaced based on age and not wear. I mean, semi's get new ones every few years due to mileage. Are you going to put 300,000 miles on your bus in 8 years? I'd be lucky to get 150,000 and I drive across country 4 times a year.
Of course you did say you had a shortie, which your tires may be smaller than the ones on my hog. I have 11R 22.5's.
04-28-2016, 09:01 PM
#359
Please don't make me drive the tires off this bus.
I think I'd be lucky to get 30 or 40K on these, then I'll time out.
04-30-2016, 04:44 AM
#360
