Old 03-09-2017, 08:32 AM   #1621
Brewerbob's Avatar
Originally Posted by ourmefa View Post
My crawler pulled up a couple more good ones I think - all have DT466 engines - some are electronic some are not.
Prisoner bus is nice but I'm more interested in this crawler of yours. Details?
Old 03-09-2017, 09:01 AM   #1622
Brewerbob's Avatar
Originally Posted by cowlitzcoach View Post
I also wonder about mixing metals. If they haven't provided for a barrier between them the electrolysis will be eating away at the different metals already.
This could be answered with an email (and probably photos) easily enough.
The price is attractive but I think this one really falls into the buyer beware category.
VERY. And it has the grunt work already done.
So, let's assume the worst. They slapped the aluminum up there AND sanded the steel bare that its coming in contact with. Worst case... not that anyone would purposely do that. What would it take to "fix" it? Pop the bottom couple of rivets and spray it? Rubber insert of some kind?
Even with the warning, I'm very interested in it. Only 91K miles. The DT466 is a good engine no? Assuming it has good tranny and gear ratios...
Originally Posted by Njsurf73 View Post
So if someone local wanted it, I wouldn't see a problem (after actually inspecting it) but I don't see it making and long trips at the moment.
I do. Some hearing protection, 16 rolls of duct tape, and a tarp.
Nobody wants to make a transition for the low to high sections!
I do.
Old 03-09-2017, 09:50 AM   #1623
Originally Posted by Elliot Naess View Post
Didn't anybody reply to you yet? Shame on us.
Welcome!
My first thought is that this bus is overpriced.
Next, it has "Dayton" wheels, which some folks like just fine, and I consider a serious drawback. Dayton wheels require skill to install straight. By contrast, Budd wheels -- like on any car or pickup -- just bolt on and you cannot do it wrong.
The engine is the predecessor of the 444 (7.3), so it is probably a reasonably reliable model of engine.
The low mileage is interesting. If it is accurate. But vehicles also deteriorate by sheer age.
Does it really have air brakes? Judging by all the wheel chocks, perhaps not. UNLESS... it has air brakes WITHOUT spring-applied parking brakes ("maxis", to old truckers). But I'm pretty sure maxis were required by law by then.
If it has a combination of air and hydraulic... run, don't walk.
The condition of the transmission is important, as those are expensive to fix.
New tires and wheels? Would that be new-to-him, or brand new? The chalk marks on that rear tire suggests second-hand.
Two new batteries? Two different models, with cables cobbled together like a child's erector set. I'm not impressed.
Thank you kind Sir! I love this site because of the wealth of knowledge here. Looks like I am off to do some more searching lol
cgbils is offline   Reply With Quote
Old 03-09-2017, 10:21 AM   #1624
$4000 tops. That's my take on it.
I still want to know the diff ratio and whether it has full-width luggage compartments. Otherwise, it's my bus down to a T.
Old 03-09-2017, 12:09 PM   #1625
Brewerbob's Avatar
Denver bus... the kid used some kind of marine grade epoxy between the AL sheeting and the steel windows. He can't remember brand or type. Think that's good enough for a barrier?
Build sheet attached but the short version is...:
- DT466E 190HP@2300 Governed to 2600
- Hydraulic brakes
- 145 amp alt
+ Engine block heater
- Allison 545 Four speed
- 65 gallon tank
- spring suspension
+ 74" roof raised to 8'
+ luggage underfloor
/ 4.44 ratio gears
- governor road speed 55
- = less than the OR bus I was looking at
+ = better than
/ = dunno
Old 03-09-2017, 12:28 PM   #1626
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
- Hydraulic brakes
- 145 amp alt
- 65 gallon tank
- spring suspension
/ 4.44 ratio gears
+ = better than
/ = dunno
Looks like more negative than positive.
Old 03-09-2017, 12:39 PM   #1627
Brewerbob's Avatar
The roof is a biggie and I lost out on the bidding for the OR bus. A $4k bid would cost me $6k by time I got it home. And that's assuming the bidding stops at $4k.
Not sure what I should do.
Old 03-09-2017, 12:42 PM   #1628
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
I would regroup and keep your eyes open. The right bus is out there.
There will be more busses that come along that will fit your needs. It's hard to wait, but it sometimes is the best play.
Old 03-09-2017, 12:55 PM   #1629
Brewerbob's Avatar
There will be more buses that come along that will fit your needs. It's hard to wait, but it sometimes is the best play.
May/June isn't all that far off for the "new" crop coming out but waiting sucks!!
Old 03-09-2017, 03:59 PM   #1630
Rameses's Avatar
I thought a high roof was a huge bonus when I was looking for a bus. I ended up getting a low roof and am extremely glad I did. I would've been really tempted to leave it the stock height if it were a high roof, but a standard roof, with a minimal raise (8"), is far superior in my opinion.
Rameses is offline   Reply With Quote
Old 03-09-2017, 06:20 PM   #1631
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
That is if you plan on full timing in it. I plan on using it as a family camper and Adventure wagon. I want a tall bus, because I am not going to do a raise. I have thought about doing an "atrium" over the shower. Or dropping the floor pan in the shower, just for comfort. But anything like that is an addition I will make after the bus is operational.
It all depends on how you plan on using it.
Old 03-09-2017, 06:39 PM   #1632
I do.
I guess you and I are on different ends of the spectrum. I see all sorts of red flags, you see "buy me".
Old 03-09-2017, 06:41 PM   #1633
Agreed. I'm MORE than happy with the ten inch raise we just did!
I almost stopped raising at 8" but the group pushed me to go the extra couple.
Everyone has different wants and needs. I think a standard roof with a *sensible* lift is a pretty sweet way to go.
Old 03-09-2017, 07:25 PM   #1634
got one
Well I took a chance on one of those several buses out of VA that were listed on gov deals. After seeing that they had some 300K and 1 million miler buses, I figured the school corporations maintenance must have been pretty good. This one is one of their lower ones at 104,915 miles
https://www.govdeals.com/index.cfm?f...1499&acctid=19
Got it for $1075 before the buyers premium. Now to go get the sucker lol. Any input on the bus would be much appreciated (good or bad). Thanks!
Old 03-09-2017, 07:43 PM   #1635
oricha1984's Avatar
Engine: gasser probably
cool looking thing
https://www.govdeals.com/index.cfm?f...25&acctid=8902
oricha1984 is offline   Reply With Quote
Old 03-09-2017, 07:43 PM   #1636
Brewerbob's Avatar
The tranny sunk it. I don't want a 55mph bus.
https://reno.craigslist.org/hvo/5991838674.html
https://goldcountry.craigslist.org/cto/6023324584.html
These might not be bad if they will take ~$5k.
Old 03-09-2017, 07:58 PM   #1637
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Anyone know anything about CNG busses with John Deere 8.1 motors? Lol couple of them up near me. They need to be inspected and they are expected to fail said inspection.
Old 03-09-2017, 08:08 PM   #1638
Originally Posted by oricha1984 View Post
I saw that too! What a cool old truck, eh?
Old 03-09-2017, 08:24 PM   #1639
Engine: Navistar 7.6L
check this thread out:vhttp://www.skoolie.net/forums/f28/wh...-cng-3818.html
DoubleO7 is offline   Reply With Quote
Old 03-09-2017, 08:30 PM   #1640
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Originally Posted by DoubleO7 View Post
Thank you!
