09-11-2018, 01:00 PM
#4121
Engine: TE 444
Rated Cap: 12
Also been converted from a manual to an auto in the past
09-11-2018, 01:01 PM
#4122
Originally Posted by cowlitzcoach
It looks like an 05 to me.
The front rear caps could have been changed but the 01 has a tag axle and the 05 has a bogey axle.
Tag and bogey axles are undriven axles. A tag axle is behind the drive axle and a bogey axle is in front of the drive axle.
Thanks.
Gotta love the old Eagles. I sure miss mine.
09-11-2018, 09:45 PM
#4123
Chassis: 40' MVP-ER
09-12-2018, 01:03 AM
#4124
Coachwork: Amtrans
Chassis: Genesis
Rated Cap: 20 (9 window handicap)
This is at a district local to me.
2003 BB TC2000 78 pass
245hp 5.9 ISB, 3060 transmission. Retarder. And is that an exhaust pipe for an auxiliary heater that is peaking out from under the battery box?
https://publicsurplus.com/sms/all,co...ew?auc=2178861
09-12-2018, 08:07 AM
#4125
Year: 2013
Coachwork: Ford
Engine: Gas v10
Rated Cap: 13
Saw this bus in my usual searches. Mileage is 148,142. And it is already registered as an RV!
Not bad, 2 roof mounted AC units powered by an Onan Emerald III Genset generator. 4 new tires and a recent oil change.
https://tampa.craigslist.org/hil/cto...695472886.html
09-12-2018, 08:12 AM
#4126
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Crown super coach II
Nice busses.
Originally Posted by shaymcquaid
09-12-2018, 10:20 AM
#4127
It even comes with a set of spark plugs.....
09-13-2018, 04:03 PM
#4128
An Allison MD3070: https://www.govplanet.com/for-sale/P...20-01-493-6059
From what I can find, it is a 7 speed. I had never heard of such an animal before.
I found the following info on another site:
The MD3070 is the same family as the MD3060's with the addition of the transfer class with another lower gear (hence the trans in all wheel drives are a 7 speed). The top 6 speeds are the same as the MD3060. What I remember on the MD3060 id that 4th gear is 1:1 , 5th .75 OD and 6th .65 OD . The WTEC shows 7 gears (on the 3070), but the "automatic" shifting are 2 to 7 . 1st must be shifted into manually for use, once any other gear is selected, 1st is locked out until manually selected again. It is a off road gear to be selected when needed
09-13-2018, 05:33 PM
#4129
Granny gear in 3060. Wonder what ratio the 1st gear is, don't see much need for it in a Skoolie.
09-13-2018, 06:08 PM
#4130
https://www.govdeals.com/index.cfm?f...4&acctid=11846
Closes in 20 minutes, at $3800 and going up $100 every 5 minutes.
09-13-2018, 07:22 PM
#4131
Originally Posted by o1marc
Holy Crap, the auction time ended with the bus at $4850. I went away thinking it had ended. In the next 7 minutes 13 more bids came in from 2 bidders driving it to $8800, $9900 after auction fees. Those guys wanted that bus really bad.
09-13-2018, 07:38 PM
#4132
Coachwork: None yet
Cool! Is the offset output yoke a normal thing for these transmissions, or are they typically straight through?
09-13-2018, 09:44 PM
#4133
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
wonder how this is titled
09-13-2018, 10:20 PM
#4134
Engine: 6-71TA
Rated Cap: 90
Tried contacting twice but no response. Perhaps, it is sold and they forgot to pull the ad?
09-14-2018, 01:02 AM
#4135
Year: 1954
Coachwork: wayne
ugggg. want parts from this....56 wayne
https://dallas.craigslist.org/ftw/ct...696889511.html
I could use a couple roof panels, five of the windows, the bus doors.
any body need some wayne body parts?
william
09-14-2018, 02:17 AM
#4136
Year: 1954
Coachwork: wayne
1944 ford bus NM
09-14-2018, 02:19 AM
#4137
Year: 1954
Coachwork: wayne
1950 dodge
09-14-2018, 02:58 AM
#4138
Year: 1954
Coachwork: wayne
1966 short bus MT
09-14-2018, 03:17 AM
#4139
BlueFish aka Todd
Seeking a Crown, Thomas, International, Blue Bird bus with DT466, Cummins 8.3, Allison trans, high roof, air brakes, and A/C.
09-14-2018, 08:03 AM
#4140
if anyone runs across any late 70s SUperiors let me know.. I need interior parts.. Seats, dash pieces, etc.. I am restoring my Superior back to pretty close to original..
