12-11-2019, 05:14 PM
#5041
Originally Posted by TJones
Great Deal! Ready for conversion!
All the hard stuff is done!
12-11-2019, 05:41 PM
#5042
what a dreamboat of a bus!
12-12-2019, 12:23 AM
#5043
1985 Blue Bird School Bus - $4000
Rear Engine
Air Brakes
Cat 3208
14 Windows
Tires look decent to good
109k Miles (?)
Runs and Drives
Has some "old bus issues"
San Jose California
Ad states the odometer and hours have "probably turned over once or twice" That's seems highly unlikely (if the odo turned over just once the bus would have 1.1 Million miles on it).. And if we assume odo and hour meter are correct, it works out to 12 miles per 'running hour', which doesn't seem too hard to believe, and if anything seems pretty low. If it turned over once or twice it would be 6 miles/hr or 4 miles/hr respectively which seems really low.
12-12-2019, 12:33 AM
#5044
1991, Cummins 5.9l, Rear Engine, 14 window, Air Everything -- $3200
From the little I know, this Bus seems like its got most everything you full size folks are looking for.
Rear Engine
5.9l Cummins (all mech I think)
Air Ride
Air Brakes
Air Seat
Underbody Storage
14 window
"no rust"
"runs like a dream"
Berkeley CA
https://sfbay.craigslist.org/eby/cto...020636119.html
12-12-2019, 04:53 AM
#5045
Chassis: Saf-T-Liner
Engine: MBE 906 Mercedes Benz Diesel
Rear Engine
Air Ride
Air Brakes
Air Seat
Underbody Storage
14 window
"no rust"
"runs like a dream"
Berkeley CA
No pics of the tires... could be $3,200 plus another $3K for new rubber.
12-12-2019, 08:51 AM
#5046
Engine: 8.3 Cummins ISC
Rated Cap: 75
https://www.ebay.com/i/192469306312?norover=1&mpt=[CACHEBUSTER]&ff5=2016414172&ff8=71532510716&audid=aud-401424578130&device=m&ff7=1613.android.com.rapidci tyjournal.news.adsenseformobileapps.com&siteid=0&i pn=admain2&mkevt=1&mkrid=711-155981-716029-4&mkcid=4&placement=520701&gclid=EAIaIQobChMI55Cgj dqu5gIVTYRpCh0Alw_4EAEYASACEgLxDfD_BwE
I want whatever this guy's smoking!!
Weren't all Silver Eagles manufactured in Belgium?
12-12-2019, 08:55 AM
#5047
Rated Cap: 75
Rear Engine
Air Ride
Air Brakes
Air Seat
Underbody Storage
14 window
"no rust"
"runs like a dream"
Berkeley CA
Actually if I was going to get a 5.9 in a full size pusher I'd want one of the later 24v electronic ones since they're turned up to 280ish HP and are surprisingly decent power wise.
Also this bus was being discussed on Skoolie Nation Facebook page, apparently a few members there went to look at the bus in person and the roof on the side by the broken windows is pushed in pretty badly. Basically the entire bus shell has been compromised by what looks like roll over damage.
12-12-2019, 10:40 AM
#5048
Engines are available in a variety of ratings. The most common 5.9 rating in school buses is 190.
#5049
EXACTLY!!!
12-12-2019, 10:59 AM
#5050
My ISB is 260hp. Zoom zoom! My 6BT is 190hp.
12-12-2019, 05:01 PM
#5051
Rear Engine
Air Ride
Air Brakes
Air Seat
Underbody Storage
14 window
"no rust"
"runs like a dream"
Berkeley CA
No one wants a 5.9 in a full size bus.
12-12-2019, 05:27 PM
#5052
That got my attention so I did a little looking for replacement caps. Richard and Karen of R&M Fiberglass don't make Eagle caps anymore but they have the molds in storage. Apparently the molds require some repairs before they would be usable.
12-13-2019, 11:54 PM
#5053
Really? I thought that's where they are usually found (but I pay very little attention to buses over ~24ft, so really I'm pretty clueless). I haven't seen many in true short buses but I haven't been looking very long. Where are they normally found, mid sized 24-34ft buses?
12-14-2019, 08:46 AM
#5054
The 5.9 has earned its reputation as a good motor, and is available is the same general power range as the 8.3 for most years. The 8.3 is cheaper and easier to rebuild and makes its power a little lower, but typically also has a lower RPM limit. You sure won't be counting cubic inches when going up a hill.
My ISB is rated at 260hp. it's got plenty of punch and will run 70 down the road. If I get 6th unlocked that'll add another 10mph (really it'll improve my MPG at 70 because 70 is plenty fast for me), my bus is 38ft with MD3060.
Generally speaking, the transmission and rear axle ration are more important factors than the engine.
12-15-2019, 03:02 AM
#5055
12-15-2019, 09:58 AM
#5056
Rated Cap: 75
Originally Posted by halsey
That "Repowered by Crown" in 1977 badge is pretty interesting. Maybe these were one of the old old gas powered buses that were later factory swapped to diesel power?
12-19-2019, 10:43 AM
#5057
Rated Cap: 75
https://www.publicsurplus.com/sms/au...ew?auc=2495786
Here's an odd one. I wasn't aware that Bluebird ever offered Cat motors in the TCRE buses. This one has a 3116 as confirmed by Vantage portal and Cat serial # lookup. Previously I was under the impression that only the 5.9 & 8.3 Cummins were available on the TCRE.
Not sure what kind of reputation the 3116 has as opposed to its newer sibling the 3126 but this bus could be worth it for the right person. AZ buses are CLEAN and will save you a ton of time and money (not) repairing rusted out floors and body panels.
12-19-2019, 10:49 AM
#5058
Rated Cap: 75
https://www.publicsurplus.com/sms/au...ew?auc=2492240
Nice 2003 AARE in Oregon. $5500 starting bid Bet they're starting to catch on about how desirable these are.
#5059
Bunch of MaxxForce7 buses on 422 going cheap. Nobody wants those and it shows! I wonder how hard it would be to bulletproof one...
12-19-2019, 10:52 AM
#5060
I hadn't seen a TCRE with a Cat but I learned a while ago that they'd build whatever you told them you wanted if that's what it took to get an order placed.
