Old 04-18-2017, 01:47 PM   #1
NOS & Obsolete
NOS & Obs Parts
Thomas Built
Freightliner
Cummins
Goshen Coach
Ricon
Braun
Cat
Lighting
Decals
Brakes
Would say Mid 90’s and up but anything is possible
Lists Available or contact with specifics
SRV082790 is offline   Reply With Quote
Old 04-18-2017, 03:00 PM   #2
Robin97396's Avatar
No Bluebird, huh?
Robin
Nobody's Business
Old 04-18-2017, 04:07 PM   #3
Jolly Roger's Avatar
Engine: Detroit 8.2
Road AC for a ford chassis with Thomas body?
Old 04-18-2017, 05:02 PM   #4
what are you looking for? most road A/C is all aftermarket, many parts are interchangeable.. ie comopressors, brackets are generic, condensors can be replaced with other manufacturers units pretty easily...
if you have A/C now, it should have a nameplate somewhere on it...
carrier, Trans/AIR, Thermoking, etc..
Old 04-24-2017, 09:41 AM   #5
Parts List
NOS & OBS Parts List
Old 05-02-2017, 07:45 AM   #6
Storage Boxes
Manufacture : Built
1 - BR-UBB1D-MODIFIED 40x20x28 Complete With Hinges,Handles and Sealed Box of hardware Has Paint Damage
2 - 1 - BR-UBB1D 40x20x23 Complete With Hinges,Handles In Good Shape
No Hardware
Fitment unknown
Do not appear to have been installed
IMG_20170501_104553127.jpg   IMG_20170501_104433585.jpg   IMG_20170501_104222547.jpg
Old 05-02-2017, 07:56 AM   #7
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Where are you?
Old 05-02-2017, 08:39 AM   #8
I am in New York
Old 05-02-2017, 09:30 AM   #9
How much for two of those storage boxes shipped to FL 32726?
Old 05-03-2017, 10:49 AM   #10
Davco Fuel Filters medium use. Cummins ISB's DT466 or Maxxforce,
Any diesel engine with fuel flow rates up to 60 gph
Class 4, 5, & 6 Trucks
Pickup Trucks
Refrigeration Units
Biodiesel Applications
See Model # Identifier PDF
PN#s
1-243052RLDAVK-07 Right In / Left Out Heated 12VDC 195W Preheater 7
Micron ( Complete Kit )
6-233050RLDAVK-07 Right In / Left Out Unheated 7 Micron
10-233053FRDAVK-07 Front In / Right Out Heated 12VDC 195W and WIF 7
Micron ( Missing Harness/Wrench )
Acorn Nut Covers 1 1/2" x 2"
400-ACX 84400
Please any Interest make an offer...
Also the aforementioned Storage boxes still Available
Davco 233050RLDAVK-07_233053FRDAVK-07.jpg   Davco 243052RLDAVK-7.jpg   Lug Nut Cover_s ACX 84400_17590.jpg   Lug Nut Covers ACX 84400_17590.jpg
Old 05-10-2017, 12:35 PM   #11
Found These today,
Both Boxes open looks to be complete but not 100%
Dunno if other components needed
Old 05-10-2017, 12:41 PM   #12
nice lookin Trans/AIR, marry those to a standard Sanden 7 series or Selttec TM-16 unless a compressor is included..
you could also use that as a Tie-In system to dash air if the van front already has dash air. yank the front condensor and use the T/A one.
looks like that is 20-30K BTU system, would cool a 4 window rear of a Bus nicely, wouldnt cool a conventional bus (even a shortie).
Old 05-10-2017, 01:15 PM   #13
Rameses's Avatar
What exactly does that mean?
Rameses is offline   Reply With Quote
Old 05-10-2017, 02:02 PM   #14
Robin97396's Avatar
Yeah, that's not very encouraging for my 5k btu AC. It didn't work last year with the bus stripped out during the hot part of the summer. I was hoping it would work now that I have insulation in the bus.
This was just a small AC that I bought in '89 to reduce humidity in a bedroom. It's amazing it still works. Mini-split system in the plans, but only after acquiring the appropriate genny.
Robin
Nobody's Business
Old 05-10-2017, 04:58 PM   #15
theres a HUGE difference in cooling a stock Moving , operating bus vs cooling a parked highly insulated one. your 5k A/C will probably do nicely until you g oto drive it on the road into the sun on a hot highway.. engine heat blasting in.. but when you want to sleep at night you'll be nice N cold
Old 05-10-2017, 05:40 PM   #16
Robin97396's Avatar
We've just started having the occasional 80* day now and then. I'm still sitting in full sun but it's comfortable so far.
My little old AC just barely fits through a fully opened side window. It fits so snugly it doesn't require any fill around the edges. To bad it's 30 years old. Mini-split system in my future with two zones hopefully.
Honestly I doubt I'll use an AC unless I leave Oregon, and that doesn't seem smart during the summer. This is a destination. Come to Oregon and cut down a tree.
Robin
Nobody's Business
