08-15-2017, 02:30 PM
#21
Chassis: Bluebird
Rated Cap: 51
I'd buy the tires if they are in good shape I'll take the outside two in the rear and leave the insides so it can be towed. I'm headed out from Pa to Utah in two weeks. I can stop buy and take them off if you want to sell them?
08-15-2017, 03:02 PM
#22
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
They are not worth it. Sorry
Sent from my LGLS676 using Tapatalk
08-15-2017, 11:44 PM
#23
I have a bus for you and I'll take 2010 1989 Ford bluebird will get you and Jaden specs entire size tomorrow
08-16-2017, 05:23 AM
#24
They ended up getting a really nice bus.
08-16-2017, 05:43 AM
#25
it looks to me like their new bus is a really nice Uograde over the previous one!
08-16-2017, 07:07 AM
#26
Wish I had that kind of money laying around.
08-16-2017, 08:55 AM
#27
Coachwork: myself
Chassis: amtran
The bus cost me 2500. After pulling the seats and putting them in the old one i scrapped it for almost a grand. 1500 is all i spent. Not a lot of money to have lying around. A new 5.9 would have cost more installed even if i did it myself.
08-16-2017, 02:03 PM
#28
id say thats a great NET cost!!!
*usually* the busses run in ohio are mechanically really sound.. the inspectors here are pretty serious about mechanicals..
08-16-2017, 03:44 PM
#29
Coachwork: myself
Chassis: amtran
That's what the dealer cut said too. It runs great. But the dash shorts out intermittently
08-17-2017, 12:44 PM
#30
id say that's a great NET cost!!!
*usually* the buses run in Ohio are mechanically really sound.. the inspectors here are pretty serious about mechanicals..
Pirate,
Abso(*&#@&lutely (agree with Chris)!!! Maybe I was one of those guys that had to have a bus. Maybe it's the 5.9L (I weeded those out). I've not seen a lot of buses anywhere near that clean on the outside much less everything else for $2500.
Congrats.
08-17-2017, 01:47 PM
#31
Navistar dashes are notorious for cutting in and out.. usually bad or loose solder joints..
if this is a 466E, the dash may be losing communication with the ECM intermittenly.. its usualy a pretty easy fix.
