08-10-2017, 02:15 PM
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Our beastie died. Need a bus. southern ohio
Killed this 5.9. The bus was only $2500. A new motor installed is more. Looking for something around $2000. Help this Dead family out. Summer tour is calling...Lock'n is near.
Sent from my LGLS676 using Tapatalk
08-10-2017, 02:36 PM
dang, howd you trash a 5.9? seems id be looking for a bone yard and swap in another one.. unless you didnt have much conversion work already into the beastie
08-10-2017, 09:23 PM
Coachwork: myself
Chassis: amtran
So much work in it. I'm nowhere near home or a shop. Just going to get a new bus.
08-10-2017, 10:56 PM
Coachwork: myself
Chassis: amtran
Chillicothe ohio. Gonna strip the bus tomorrow and uhaul all the stuff (solar panels, fridge etc) to chatlotte n.c.
08-11-2017, 06:03 AM
Engine: TE 444
Rated Cap: 12
What year bus? Which transmission, tire size?
08-11-2017, 10:09 AM
Coachwork: myself
Chassis: amtran
It was a 1992 carpenter 11r 22.5
Allison 4 speed
08-11-2017, 11:17 AM
Engine: TE 444
Rated Cap: 12
If the tires are good, you might want to keep them
08-11-2017, 02:22 PM
Can't limp it home at 30mph? Granted that's a long haul but easier to replace an engine than everything else. First listing is $1600. Don't know anything about 5.9s. Apparently there are 12 valve and 24 valve.
12 Valve Cummins Engine | eBay
08-11-2017, 04:12 PM
Coachwork: myself
Chassis: amtran
The block is cracked. Its done. I only have 2500 in the bus. It will cost that or more for a new engine installed. I'm on the road and don't have a place or way too switch out a motor
08-13-2017, 10:41 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Condolences on your loss.
08-13-2017, 10:46 PM
Coachwork: myself
Chassis: amtran
Uh....Thanks for the advice. We got another one. international 466 push. 1998 and it has 5 speeds instead of 4. We love it
08-14-2017, 05:27 AM
Looks like a hell of an upgrade to me!
08-14-2017, 06:21 AM
columbus here if you need any tools or such.
I also have the navistar software and can reprogram settings on your computer if you need.. (I havent figured out how to unlock 6th on an MD-3060 yet though)
Nice new rig!!!!!
08-14-2017, 08:26 AM
Coachwork: myself
Chassis: amtran
Nice new rig!!!!!
Thanks. The mechanic we were near when we died upped us from 65 to 90. Not that it will do it, but it's not 65. Are you saying there is a 6th hear it something?
08-14-2017, 08:34 AM
Coachwork: myself
Chassis: amtran
I meant to make a cheat code joke. Like; you mean i can get unlimited lives and ammo?
08-14-2017, 09:48 AM
good deal, if it has an MD-3060 in it then it likely has a 6th gear that is computer locked.
if it has an allison 2000 series. and is PRE-2006 then the 6th gear requires mechanical changes and computer changes.
I didnt see what trans you have.
08-14-2017, 10:00 AM
Wow, that was quick.
08-14-2017, 10:01 AM
Coachwork: myself
Chassis: amtran
The luckiest deal I've ever gotten.
08-14-2017, 10:08 AM
My FIRST bus from long ago came from Chillicothe.. ironically it was pretty rusty free and ran great...
08-14-2017, 10:10 AM
Coachwork: myself
Chassis: amtran
This one is relatively rusty free. It has some front end noise i assume to be leafs rubbing.
