Old 03-03-2009, 11:08 PM   #1
Year: 1983
Chassis: 1723/TK
Engine: 345
Power Steering pulley
[]Okay for those of you that said this was no big deal!!!![/u] Well it has certainly turned out to be a very hard part to find? So wiht all the knowledge I have gotten from this forum I'm still at loss. I'm looking for a Power Steering Pulley for a 1983 International buss. And the part has been discontinued!!!The engine is a gas engine 345. The Buss is a small Blue Bird School Buss. The Pulley is a 5/8th hole with a streight Keyway. The diameter across is 6" 1/4 The part number is 488782-KI, 2 Belt. The vin number is 1HVBA17B9DHA31061 . If anyone has one or knows where I could get this part? I have attached photos of the part.
Please Plesae Helllllppp...
Creeker is offline   Reply With Quote
Old 03-04-2009, 07:02 AM   #2
the_experience03's Avatar
Re: Power Steering pulley
Are you just worried about that chunk that is missing? If that's the case then I think you could probably juts run it unless it has given you problems. I don't think it should though. At worst you might want to take a flat file on the inside where that piece is missing and make sure that it is smooth.
Old 03-04-2009, 12:08 PM   #3
Year: 1983
Chassis: 1723/TK
Engine: 345
o The Pulley was actualy put on backwards and then they used JB Weld to attach it. I need a new one as I said in my post.
Old 03-04-2009, 03:15 PM   #4
try an industrial power and transmission supply house, MSC, Graingers, Motion Industries, Mcmaster-Carr, etc and have them match up the physical characteristic's, diameter, hole dia, offset and belt pitch, their should be a generic sheave available that will be close enough to work.
Power steering Reservoir? ihowell2077 Mechanical and Drivetrains 1 10-11-2013 11:08 AM
Power steering failure auto-sales International | Navistar Drivetrain 0 06-29-2013 05:58 AM
power steering pump Atridox Short-Bus Conversion Projects 7 04-21-2011 12:18 PM
Need help with Power Steering kirkndopp Conversion General Discussions 2 07-07-2010 10:32 PM
Alternator and Power Steering paul iossi Conversion Tutorials and How-to's 6 02-16-2009 07:38 PM
