Old 06-21-2018, 11:12 AM   #11
Interesting! I've been following this stuff for 4 years now, and this is the first I've heard of the ISL 8.9 liter engine.
An unattributed quote on the irv2 forum states:
"The ISL diesel carries a bore x stroke of 4.49 in. x 5.69 in. (114 mm x 144.5 mm) for an overall displacement of 8.9 L. Again, another family resemblance is the bore size, which is identical to the ISC engine.
The block, a gray iron unit features cast-in ribs for enhanced stiffness. "If you look at the block, it's really, from a casting standpoint very similar to the ISC block," said James D. Kahlenbeck, chief engineer of the ISL. "It's basically derivative of the known ISC platform, with some different machining because of various heavy-duty design requirements."
I also found claims that the heads for the 2 engines were identical, that the 8.9 had a 24v configuration, and that the ECMs were "different". Oh, boy, that's helpful.
Cummins as usual was heavy on sales and light on hard info. I couldn't find a reference to diesel-powered ISL's but lots on the wonderful 2017 CNG model.
There's a decent amount of aftermarket, and Cummins will support it for a while, I'd guess.
Has anyone anywhere heard of this engine in a bus before? School Bus Fleet Forums had one hit, excepting the fluff and press releases.
Old 06-22-2018, 12:14 PM   #12
Thank you so much for the info!! The seller wasn't able to make it yesterday so we are hoping to see it either today or over the weekend-will post an update once we see it (hopefully with the keys in hand if it goes well!).
CJ1417 is offline   Reply With Quote
Old 06-22-2018, 12:25 PM   #13
brokedown's Avatar
I'm unconvinced that it's not the 8.3. It looks like a TC2000 to me, and those were made with the 5.9 or 8.3. If it came with an 8.9 that's going to be something pretty unique.
https://en.wikipedia.org/wiki/Blue_B...000#Powertrain
Old 06-22-2018, 12:27 PM   #14
Either way its real hard to beat a low mile big Cummins in a bus.
Roll Your Own Build Thread
Old 06-22-2018, 12:51 PM   #15
Brokedown, I'm leaning towards your theory here. IF it is an 8.9, and that's a long shot, my guess would be that it was a retrofit with whatever they had lying around or could scrounge locally and quickly. OTOH, that one quote did say that the block casting was "based on the ISC" i.e. the 8.3 so if the mounting pads and the bell housing matched up, it'd be a slam dunk.
Since the bore remained the same, I would say that this is a clear case of different strokes for different folks.
Old 06-22-2018, 12:56 PM   #16
brokedown's Avatar
I'm expecting its a slip of the tongue from someone who isn't knowledgeable about that which they speak. Kind of like the whole "AT543" that you can find a lot of references to but doesn't actually exist. Confusing the 5.9 and the 8.3 naturally gives you either a 5.3 or 8.9.
If it actually has an 8.9 everything I've read indicates it was swapped by the owner. Not sure how I'd feel about buying a franken-bus.
Old 06-22-2018, 01:06 PM   #17
IDk, a prison could order any bus configuration they want. They're spending state/fed dollars and if that engine was an option I could see them ordering it that way.
Pics of the engine and vin would tell all.
I do think its most likely an 8.3 though.
Old 06-22-2018, 03:29 PM   #18
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
Just buy it already!
- Thomas
The Daily Driver Bus Build
Thomas1985 is offline   Reply With Quote
Old 06-22-2018, 09:52 PM   #19
Here is the VIN: 1BABKB7A6TF064049. We have plans to see it tomorrow so we will take pics as well in case we need further expert advice from this forum!
Old 06-22-2018, 09:53 PM   #20
Going to see it tomorrow so hopefully all works out!!
