Old 06-22-2018, 09:40 PM   #21
plfking's Avatar
Rated Cap: 34
Originally Posted by CJ1417 View Post
Here is the VIN: 1BABKB7A6TF064049. We have plans to see it tomorrow so we will take pics as well in case we need further expert advice from this forum!
Gates decoder says it's a 8.3L.
Don
The Busted Flush
Old 06-22-2018, 09:41 PM   #22
joeblack5's Avatar
Year: 98
maybe the inmates had a say in it and wanted a get away bus with a larger engine to outrun the cops.
later j
Old 06-23-2018, 06:40 AM   #23
I kinda figured.
CL sellers...
Roll Your Own Build Thread
Old 06-23-2018, 04:48 PM   #24
You were all right-8.3! We had a chance to drive it but have a couple questions for the group before we buy. We are planning to convert for full time travel so we really want to make the right purchase first time.
1. The wood floor seems completely rotten. We cannot see any rust underneath the bus and know we have to rip the floor out-is the rotten wood any reason for concern?
2. With it being a RE there is a switch for front or back to start the bus. The bus will run when set to back but intermittently shuts off while running when set to front. Any thoughts on this issue?
3. How do we figure out the type of transmission? It is a solid shifter (attaching picture).
4. Attaching 2 picture of boxes in the rear of the bus. The first is back at the top-looks like a heater but we arenít sure and would hope to be able to pull it out. The other is just behind he wheel well. The seller isnít sure what either are.
Thanks everyone for the input-very much appreciated!
CJ1417 is offline   Reply With Quote
Old 06-23-2018, 05:24 PM   #25
The wood probably rotted from the inmates various fluids.
Old 06-23-2018, 05:38 PM   #26
brokedown's Avatar
If the wood is soft it's a pretty safe bet there's some soft metal under it too. Don't plan on skipping removing the floor!
Old 06-27-2018, 03:51 PM   #27
Elliot Naess's Avatar
Engine: 5,9 Cummins
If the engine is an ISC, it has electronic fuel injection. IS stands for Interact System.
If it is a 6C8.3, it is mechanical (good!).
In between was the C8.3E, where the E stands for Electronic.
To identify a mechanical engine, look for an in-line fuel injection pump on the left side of the engine, with a mechanical accelerator-pedal linkage to it.
Buy it, regardless!
(Assuming the price is reasonable.)
Elliot
Old 06-27-2018, 04:36 PM   #28
Oddball's Avatar
Engine: Cat 7.2 C7 I6 Turbo
Rated Cap: 66 ankle biters
Just think, you can paint CON-AIR on the side and no one will mess with your bus!
Oddball is offline   Reply With Quote
Old 06-27-2018, 04:38 PM   #29
If you buy it, and start demolishing for a build, anything you find that looks like a weapon or drugs, call the cops. Let them take it.
Last thing you want to do is put it aside or throw it in the trash and a cop finds it.
yfrank14 is offline   Reply With Quote
Old 06-28-2018, 02:14 PM   #30
Thank you to everyone for the input! We ended up having a mechanic take a look at it and we decided to pass based on the amount of work (and money) required to fix it up for full time travel. Our search continues!
