Originally Posted by TJones
You may be able to run the engine serial # through a cummins dealer. If a cummins dealer did the rebuild there may be record of it.
Im not sure that the paint is as new as it is clean. See if the paint looks that clean on the back of the engine in a place not easily accessible by power washer or rattle can. Also look for engine color paint on parts which likely would have been removed for a rebuild.
Ted
I attached some pics of the engine bottom in my response to BlackJohn (I did not take these). I cannot see the back side but it appears that the paint was sprayed while engine was in frame.
Also, the transmission Re-Trans tag has the number 2008196 under the S/N number. I am guessing that is the Mfg. or Re-Trans date but not sure.
