Old 01-31-2009, 05:33 PM   #1
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
REFLECTIVE STRIPE
OK DOES ANYBODY KNOW HOW TO REMOVER THE REFLECTIVE YELLOW TAPE OFF A BUS ? I DON'T WANT TO HAVE TO TAKE A GRINDER TO IT.THINKING SOMEONE HAS COME ACROSS THIS PROBLEM BEFORE TOO. HELP THXS
keith is offline   Reply With Quote
Old 01-31-2009, 06:01 PM   #2
Coachwork: na
Chassis: na
Engine: na
Send a message via Yahoo to drchefscott
Re: REFLECTIVE STRIPE
Have you tried a heat gun and a plastic scraper? The heat gun should losen the glue on the rear enough to scrape it off.
drchefscott is offline   Reply With Quote
Old 02-02-2009, 10:29 AM   #3
Coachwork: na
Chassis: na
Engine: na
A few things I forgot to add. If you don't have a heat gun, you don't need to go rush out to get one. It will take a lil longer but a hair dryer on high will work just fine. I recently purchased a 1996 F150 that was a local electrical contracting company truck. When they removed their comapny sticker, it left a LOT of glue residue on the doors. Here is what I did:
I took WD40, a hair dryer and Flat Razor retractable (no blade) handle. I removed the blade from the handle, sprayed a lite coating of WD40 on the sticker and hit it with the hair dryer (WATCH the fingers...its HOT) and lightly scraped the glue away.When I finished the one area, I applied another light coat of spray and went at it again. The lubricant assists in the removal of the glue and allows the unit to scrape without getting snagged on the paint. It worked well and was gone in no time. Don't forget to wash the surface once your done to remove the lube residue.
Old 02-02-2009, 05:29 PM   #4
I would try the CAPS lock key first. All caps makes posts more difficult to read.
Abbott is offline   Reply With Quote
Old 02-02-2009, 08:47 PM   #5
Ray_WA's Avatar
Engine: 6.2 liter diesel
Rated Cap: 24
Actually, that is not true. People with very poor vision prefer all caps because it is easier to read. It may not be as pretty, it may not be what you're used to, and it may make you think they're "shouting" at you, but it's not harder to read.
-Ray
Pack up your bus and bug out to the hills!
Ray_WA is offline   Reply With Quote
Old 02-05-2009, 10:22 AM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
how did we get onto caps ???????????????????????????????????from reflective stripe
Old 02-05-2009, 04:31 PM   #7
Coachwork: na
Chassis: na
Engine: na
Who knows. So did it work with the stripe?
Old 02-06-2009, 04:50 PM   #8
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
don't know if it works or not ,,,,too cold had to use the heat gun in my pants to stay warm,,,,,hehe ,,,,,hope to do so this wkend ..thxs
Old 02-12-2009, 12:49 PM   #9
Coachwork: ward
Chassis: international
Engine: 7.2 diesel
Rated Cap: 69
Also try mini torch like plumbers use in extreme condition
racetearoffs2 is offline   Reply With Quote
Old 02-15-2009, 12:14 PM   #10
sportyrick's Avatar
Chassis: F33695
once bought some vans with lettering all over them, heat gun works great, just heat the tape and pull it off--- slowly. sportyrick
Old 02-15-2009, 03:29 PM   #11
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
OK boys girls i got the heat gun and plastic scraper and it work good ,but unless you want to buy stock in plastic srcarper i would use a matel one just dull the edgae down,,, cause after few heats it go lemp
Old 02-27-2009, 01:17 AM   #12
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
-Ray
THANK YOU RAY !!!!!!!!!!!!!!!!!
CAMO-MONSTER
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 03-22-2018, 08:43 PM   #13
Engine: 3800 T444E
I took a window razor and was able to pull the stripes off and little strips. It did scuff up the paint, but I'm planning on painting the bus anyways. My bus was primed with a gray paint, and then the yellow one over it.
My only problem is I'm left with the sticky residue. From what I've read and seen videos online, WD-40 is the way to go. I've also been told and acetone-based cleaner is very good too. The acetone cleaner is probably best to remove the residual WD-40.
Finally, before we paint the bus, we will be sanding and wiping the whole bus down with either acetone or MEK to remove any dirt or Oils.
syntel is offline   Reply With Quote
Old 03-23-2018, 12:23 AM   #14
bus-bro's Avatar
Engine: 3208 na boat anchor
I've heard that xylene works good on decal goo. I did it the hard way and rubbed the stuff off.
I wouldn't wipe the bus down with MEK. That stuff kills without PPE. Lacquer thinner is a much cleaner high, though personally I'd degrease with TSP and water.
Old 03-23-2018, 09:43 AM   #15
I tried the heat gun yesterday. The reflective tape came off without much difficulty. So did the paint and primer. When I scraped the tape I went right down to shiny metal.
I am going to try again using WD40 and a bit less heat.
Old 03-31-2018, 12:16 AM   #16
This is what we use on vehicles in the printing business to remove the adhesive residue:
https://www.signwarehouse.com/produc...=rapid+remover
You spray it on, let it sit for a couple of minutes and scrape off with a plastic blade or squeegee.
Plastic Blade: https://www.signwarehouse.com/shop/m...e=HT-SRPR-BH25
Squeegee: https://www.signwarehouse.com/produc...lts?q=squeegee
wtd67 is offline   Reply With Quote
Adhesive Remover for left over glue under reflective stuff. 68camaro Conversion Tutorials and How-to's 7 04-14-2012 10:38 AM
