Old 02-16-2017, 12:24 PM   #1
Year: 1949
Coachwork: Crown SuperCoach
Engine: Cummins NNH 220
Rated Cap: 79 PAX (little kids)
RT or RTO-910
Hi all,
I'm looking for an RTO or RT-910 for my 1949 Crown. Has been upgraded to a 220 Cummins.
Ideas??
Thanks
--Mike
FolkBus is offline   Reply With Quote
Old 02-16-2017, 09:14 PM   #2
Alan N's Avatar
Year: 1975
Chassis: Gillig
Patrick Young in Fresno if you can get his attention.
Alan N is offline   Reply With Quote
Old 02-16-2017, 09:21 PM   #3
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I've tried many times to get a hold of him, never had any luck
Old 02-16-2017, 09:51 PM   #4
I think Patrick is in the Philippines until April or May.
Almost any truck wrecking yard will have the transmission that would work well for you. The nice thing about all of the Eaton Fuller transmissions that were used by Crown and Gillig is they all used the same universal shift tower mechanism used in Class 7/8 trucks. In other words, outside of changing the length of the driveshaft or changing the universal joint it shouldn't take much work to swap a transmission with OD into your bus.
If you are not going for an OD transmission the question has to be asked why would you bother making any changes?
Old 02-17-2017, 12:09 PM   #5
Year: 1949
Patrick's phone # or email??
