Old 10-31-2006, 06:28 PM   #1
Elliot Naess's Avatar
Engine: 5,9 Cummins
Seeking leads to 40 ft Bluebird front diesel on West Coast
The old $250,- gasser having died, pretty much on schedule, I am
ready for a more permanent bus. And I learned enough along the
way to have a pretty good idea what I want:
So if you know of a rust free 40 foot long Bluebird flat nose
with front mounted diesel engine on the West Coast, I'd like to hear
about it. This model seems to be named TC-2000. The 40 footers are
usually called 84 passenger -- they have 14 rows of seats. From
a distance, you can count 14 windows, not including the driver's
window.
There are several in Oregon, and I have even looked at some of
those, but the prices are steep.
I believe Thomas has also made this style bus, and that would also
be of interest.
With all the little school districts out there, "my" bus is probably out
there, somewhere. Thanks for keeping your eyes open!
Old 10-31-2006, 09:45 PM   #2
GoneCamping's Avatar
Seems to me I saw numerous Front motor/flat front Blue Birds listed on publicsurplus.com in Utah... May not be west coast, but certainly a lot closer to you than it is to us here on the east coast!
Publicsurplus.com is pretty good, that's where I bought my Thomas from...only Cities, states, and govt entities use this auction...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 10-31-2006, 10:54 PM   #3
Engine: 5,9 Cummins
Thanks! Yes, I have that site bookmarked. But it seems to have
few entries on my coast. And Utah has rust. But that's precisely
the type of lead I'm hoping for.
Anybody near Las Vegas, Nevada? I think I have seen front engine
flat nose Thomas buses there.
Old 11-20-2006, 04:59 PM   #4
Engine: 5,9 Cummins
Got one! Fourty feet of Bluebird TC2000 FE with 5,9 and 545. First Student has a couple more of them in McMinnville, Oregon. Now I have to start all over!
Old 11-20-2006, 06:13 PM   #5
Les Lampman's Avatar
Cool!
I'm starting over too...we should start a club...some are already there ahead of us (a certain Jacuzzi guy comes to mind) and I think Steve is ready to take the plunge again!
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 11-20-2006, 06:20 PM   #6
Engine: 5,9 Cummins
I always considered the first bus to be my "training bus". For $250,- --
not much to lose! And I sure learned a lot. Now I can get serious.
And this roof will get raised; I'm bald enough on top as it is!
Old 11-21-2006, 08:47 PM   #7
The Thomas I just got has the drop roof; it comes down 3" from the entry area putting the interior height right at 6' even. I thought about raising the roof and all the nice things that would come with that. But then I looked in the mirror and realized that old dude there would have to do the work and he's chicken...so it stays as is!
Les Lampman
Skoolie.net Gallery
Old 11-21-2006, 09:25 PM   #8
Engine: 5,9 Cummins
Oh sure, it will be a lot of work, but I think I have figured out a good method. I plan to use six guide posts made from sections of steel tubing that fit inside each other. About 2 inch square. I'll fasten the bottom of this telecoping post to the wall below the windows, all the way to the floor, and the top tube to the roof. Then I'll cut. Then I'll use good old fashioned bumper jacks to lift the roof, while the telescoping posts keep it straight. When it is high enough, I'll weld the guides right there. Then I'll add more posts, and also diagonals inside the two walls that cross the bus. Then skin with aluminum.
Of course, this plan will change by the time I start on the job!
Old 11-22-2006, 10:17 PM   #9
I've seen several sites showing the process; it actually doesn't look too bad. But...I really, really (really) wish I had taken metal shop in school and not wood shop. I can use a sawzall and do basic stuff but I can't weld and fabricating the caps (out of metal) very much intimidates me. The folks that know how to work metal really make me jealous! I figure I can make the interior of the bus look pretty nice but I better leave the outside alone (other than paint).
Les Lampman
Skoolie.net Gallery
Old 11-22-2006, 11:30 PM   #10
Engine: 5,9 Cummins
Les:
Indeed!
I'm a pretty fair fabricator, so I'm not worried about getting the roof lift done. But buses are still new to me; most of my fabrication has been Kinetic Sculpture Racers and that sort of thing. (See avatar -- Yes, that's me in one of my Kontraptions! We do have fun!) Over the last year, I've seen a couple of reports from guys who have raised their roofs, but now I cannot find them. Any clues? I'm pretty sure I have a good method figured out, but other people's experience is always valuable.
Happy T-Day!
Old 11-23-2006, 09:39 PM   #11
I know exactly where you are coming from on that. I too wanted to raise my drop roof Thomas, but I'm no metal worker either. I watch my boss build some race cars and learned a trick or two, but I'm a real novice when it comes to working metal. The roof was really something that I figured was a little too much for me to engineer and given my limited abilities in this area decided that my 5'-7" body wasn't going to have too many issues with a 6' ceiling...
So for me the roof stayed too! However, next time I try this, the bus WILL HAVE a raised roof, and it will also already have the compartments below. To be honest, I think the next one may be a Greyhound type of thing instead of another School bus. But I gotta finnish this one before I can think about another one.
Plumbing on mine is almost done, next comes the wiring!!
*Cliff*
Old 11-23-2006, 11:51 PM   #12
Les:
Indeed!
Happy T-Day!
Happy Thanksgiving to you and yours as well.
The roof raising sites I remember are:
Blackman Family
Echo & Angel right here in our gallery
And I know I've seen a couple of others but can't find them again. I'll post here if I can remember them.
Les Lampman
Skoolie.net Gallery
Old 11-24-2006, 11:14 AM   #13
Engine: 5,9 Cummins
Thanks, Les! I missed Echo and Angel because their lead photo does not show the roof raised.
The front cap is going to be the tricky part, yes. I'm hoping I can go straight up, but I have also built a couple of three-dimentional things in fiberglass in my day, so that is a valid option.
Now let me study those sites.
Old 11-24-2006, 12:10 PM   #14
Engine: 5,9 Cummins
Hey, that Todd Blackman did a nice job! (Be advised, I got pop-up ads while reading it.) I wouldn't want to fool with the windshield, though. I'm thinking I can split the front cap instead, leaving the windshield frame intact.
Old 11-28-2006, 09:04 AM   #15
Doggone it! You convinced me to think more about raising the roof so I did more searching on the Internet and came to the conclusion that it's something we should do. The argument that convinced me was the need for better insulation in the floor and ceiling (which I was already trying to find a solution for with our current 6' of headroom).
I did a drawing of the bus with the raised roof...it's here.
I agree about the windshield part. My intention (as you'll see from the photo) is to cut the roof at the frame just behind the entry door and driver's seat and form a transition there. My thinking was 1) that's where the transition takes place on a Thomas with the taller factory roof (that's where mine dips down now), 2) I'd end up with not messing with the drivers side window (I'll replace it but not have to change its size) or the entry door arrangement although I'll change it to a solid swing door (standard motorhome style), and 3) I'd not have to deal with the side curves of the roof at the front of the bus. Maybe that's not as bad as I'm envisioning but it seems if you cut the cap horizontally then you've got to match the ends of the filller piece with the outside curve of the cap and, at the same time, meet the curve of the roof panel. [I may be over-thinking this! ]
Les Lampman
Skoolie.net Gallery
Old 11-28-2006, 10:36 AM   #16
Engine: 5,9 Cummins
Good morning, Les:
The front cap will indeed be the trickiest part. Here is what I have in mind. I plan to "sneak up on the front cap from behind" horizontally at the top of the driver's side window, and then make a vertical cut where the surface is reasonably vertical. Then go across the cap at the widest point. I hope to be able to bridge the gap with sheet aluminum, putting the sheet inside the cap at the top and outside the cap at the bottom so it will be naturally rain resistant. I would have to use very thin aluminum in order to work it, but I plan to support it with expanding foam on the back so it won't dent too easily. What do you think?
Old 12-09-2006, 08:26 PM   #17
Yo
I've been looking for a tc-2000 as well, does anyone know if they come with a manual tranny?
1989 TC 2000; 235,000miles; 5.9 cummins with Alisson 545; Straight veggie burning with onboard filtration. Converting to a Toy Hauler for the summers racing motorcycles.
dlor1 is offline   Reply With Quote
Old 12-10-2006, 09:56 AM   #18
Good morning, Les:
Hi Elliot,
Geez! I read this a couple days after you posted it, meant to reply, then got busy and forgot to get back to it.
Looks like you have a plan! My situation is just a bit different in that Thomas makes the entrance area (from the leading edge of the cap back to the first frame) tall (about 6' 3"). Then at the first frame they either keep going straight back for the "standard" roof with 6' 3" headroom or start the transition to go either 3" down or 3" up for the short 6' top or the tall 6'6" top repectively. So on my bus it makes the most sense (I think ) to make the vertical cut at the second frame (which is at the rear of the entry door), jack the roof up 12" and then make the roofline transition between the first frame and second frame. That's a rise of 12" over a 29" distance; at least on paper that looks pretty good. It leaves the first 18" of roof (and the cap) as is.
The tough one for me so far is the rear of the bus. I want to leave the rear window intact; my wife like the openess it gives in what will be the bedroom area and it's already an emergency exit and a way out of the bus if bad things are happening between the rear bedroom and the front door. It almost looks like I'll have to do to my rear cap what you're contemplating for your front cap. So far I haven't figured out any other way to cut the rear corners without messing up the rear window.
I may just end up leaving the roof alone. The "biggie" is the floor. I'm not worried about the ceiling as I've decided to remove all the metal interior ceiling panels and install some high quality insulation and then install a plywood ceiling for a thermal break (and cover that with something like vinyl or carpet or such) and that won't drop the ceiling height from where is now (at least not more than an 1/8" or so).
But I don't know what I'm faced with on the floor. Somehow I have to make sure it's fairly well insulated and also gets a nice looking surface. Once I remove the rubber floor and the subfloor that's in there now I suppose I'll have a better idea of what I can do. But if the solution involves any more than gaining just a little floor thickness then I'll have to deal with the headroom issue.
Les Lampman
Skoolie.net Gallery
Old 12-10-2006, 05:00 PM   #19
Engine: 5,9 Cummins
Hi Dlor1:
I don't know if they made them with manual trannies, but I learned something valuable about the automatics:
Background: There are two common automatics in our kind of vehicles; the "slushbox" AT545 which lacks torque converter lockup, and the MT643 which has lockup. The 545 is rated for maximum 30.000 pounds GVWR (max loaded vehicle weight). The 643 is good for 73.280! (That odd number used to be the max for 18-wheelers in some states.)
So: My 1992 TC2000 has a GVWR of 31.000 lbs. Therefore, Blue Bird HAD to put the big tranny in it! My BB is 40 feet long -- 14 rows of seats; 84 little scholars. So there's the clue for a MT643; l-o-n-g bus.
Pablo:
I just measured mine to 9'8" tall. So you have a long way left to 13'6"!
Old 12-10-2006, 05:18 PM   #20
Engine: 5,9 Cummins
Hello again, Les. No need to apologise for being busy; we all are!
I have been around hot rod cars a bit over the years, where it is common to LOWER the roof. Same issues, just in reverse. Look for vertical sections that won't need angles modified after the height change. Very difficult to create a nice taper or compound shape, such as on a fastback car.
At the rear there will be a "toy box" ramp, so all bets are off there. Just lots of 1" square and 1"x2" box tubing, I expect.
I don't understand why people tear out the old floor. That has to be a ton of work! Unless it is that the plywood is rotten like on my first bus -- the floor was actually soft in many areas. On Millicent (my new TC2000) I will leave the floor alone. Mind you, we are not trying to make Millicent into any kind of Wanderlodge. Everything will be crude and simple and functional. Drag pounds of mud in on our shoes and hose it out with the garden hose.
I'll try to chronicle the roof lift here.
looking for a diesel short-bus on Canada's west coast chev49 Classifieds | Buy, Sell, Swap 1 06-22-2012 01:27 PM
Bluebird, or other FE flat front bus, around 12 windows dentedvw Classifieds | Buy, Sell, Swap 13 04-12-2010 10:25 AM
WANTED: junky Grand Piano on West Coast Elliot Naess Classifieds | Buy, Sell, Swap 0 03-10-2010 01:32 PM
West Coast buses Mulelover Conversion General Discussions 12 01-17-2010 12:22 PM
Seeking 36ft bluebird w/ cummins 5.9 dlor1 Classifieds | Buy, Sell, Swap 0 08-01-2008 10:47 AM
