Old 07-06-2017, 01:50 PM   #1
fasthuhpat's Avatar
Coachwork: Ward Senator
Chassis: Crane Carrier
Engine: 366 BBC, CNG
Selling, 1991 Ward Senator on Crane chassis
Think it might be time to sell. Bus was run by Tulsa public schools on CNG for 85,000 miles. I just converted it over to Gasoline 3 months ago and it runs great! Installed a NEW Holley 600 vacuum secondary carb and an aluminum 70 gallon gas tank and electric fuel pump. Has Air brakes, Allison Auto, 6 new tires with less than 300 miles on them. Onan BGA 5.0 Generator with it's own 10 Gallon fuel tank with sending unit. Will be installing remote start and gauge in the next few weeks. Has inside wired down drivers side in conduit, breaker panel with shore/ Generator switch and a 25' shore cord. Has 15,000 BTU Carrier roof mounted A/C. Has some windows removed and covered in 1/8" aluminum on the outside, insulated and skinned inside with gray sheet metal. RV entry door, Has a steel and aluminum wall inside 14 foot from the back of the bus (was going to make a toy hauler) with a sliding pocket door. Built in Microwave, small sink shelf (uncut) small cube fridge, and portable Toilet (unused) comes with fresh water and black water holding tanks (both new and unused) and a RV Toilet (also unused and new) I will take some new pictures of is this week end. TITLED AS AN RV IN OKLAHOMA. $6000.00 FIRM.
fasthuhpat is offline   Reply With Quote
Old 07-07-2017, 03:03 PM   #2
fasthuhpat's Avatar
Some construction pictures
Here are a few pictures of the RV door, Inner skins, Inner wall with sliding door,
Electrical details etc. I will still add current pictures this week end.
Old 07-09-2017, 06:02 PM   #3
fasthuhpat's Avatar
Sunday Pictures
Here is some from today
Old 07-12-2017, 04:05 PM   #4
fasthuhpat's Avatar
More pictures
Here are a couple more from when I first got it.
Old 07-12-2017, 04:46 PM   #5
oricha1984's Avatar
Engine: gasser probably
why r u selling it?
seems like you put hard work into it.
oricha1984 is offline   Reply With Quote
Old 07-12-2017, 08:09 PM   #6
fasthuhpat's Avatar
Too many projects and not enough time!!
Old 07-18-2017, 09:30 AM   #7
fasthuhpat's Avatar
More Info
Had some questions for Info I didn't list.
Bus is 31' long
I'm 5'10" and my head clears the A/c lower vent unit on the ceiling. so bus is standard height, can measure if needed.
Bus will comfortably cruise down the highway at 65-70 mph, I have had it to 80 (but that's just ridiculous in a school bus)
Floor deck is steel with rubber deck (no wood)
NO RUST (other than light surface rust on the roof and around empty screw holes from old mirror mounts) Solid Solid Solid Bus
Engine runs great even though it looks to have the Original spark plugs!! Yes these are on my list to change out.
Old 07-31-2017, 03:04 PM   #8
fasthuhpat's Avatar
Updated picture
Worked on the bus yesterday, got the generator exhaust finished, the vent on the generator door and the gas filler door for the 10 gal generator fuel tank.
Old 08-11-2017, 11:08 AM   #9
fasthuhpat's Avatar
Deal fell through, STILL for sale.
Old 08-29-2017, 09:30 AM   #10
fasthuhpat's Avatar
Still available
