Old 08-07-2018, 11:44 AM   #1
Coachwork: MB-IV Girardin BlueBird ADA Minibus
Chassis: E350 Super Duty
Engine: 7.3 L Powerstroke Diesel
Short School Bus Skoolie 2001 7.3 L Powerstroke Diesel Chassis
Pictures and contact information is in the Craigslist ad.
https://bend.craigslist.org/cto/d/sh...664021002.html
Price: $11,000
If you've been thinking of doing a short school bus conversion and don't know where to begin, then this is the opportunity for you! Most of the work has been done for you! This is a rare, super clean, low miles bus with a highly valued engine that isn't made anymore. Access to under bed storage from the front AND the side of the bus! It can tow 8000 lbs! The van chassis doesn't require any special licensing to drive and it is easy to get insurance from Geico.
WHAT'S BEEN DONE
Demolition - chair removal, floor removal, floor hardware removal
Wall insulation - three layers of it!
Paint with a special, one of a kind texture
Flooring - from the insulation to the finish floor
400 Watt Solar installation *done by a professional* - Kevin at Bend Mobile Solar
Raised bed with a brand new full size futon. Slept on ONCE!
WHY AM I SELLING IT?
I really don't want to. It makes me sad to give it up. However, I need to focus on other, less exciting, excruciatingly boring things.
SOLAR INSTALL SPECS
Aims Power 2000 Watt 12 VDC Pure Sine Inverter Charger w/6000W Surge
https://www.amazon.com/gp/product/B00I36K1VQ
Blue Sky Energy Solar Boost 3000i MPPT Charge Controller, 30 Amp 12 Volt
https://www.amazon.com/gp/product/B077PBB2KW
QTY 4 VMAX V6-225: 6.2kWh 24V AGM Solar Battery Bank for Home, RV, or Industrial (4) 6V 225Ah AGM Deep Cycle Batteries 6 Volt Maintenance Free
https://www.amazon.com/gp/product/B075WPYFXZ
The four 100 watt solar panels came directly from Renology.
I also have the parts for installing shore power, 12v and electrical outlets if you are interested in buying them. I will be posting another listing for those.
I will be showing the bus at the Bend Home Depot on Saturday, August 11th. Motivated buyers with cash in hand can make an appointment to see it earlier.
ReverendMother is offline   Reply With Quote
ada bus, diesel, short bus, van chassis
