Old 04-21-2006, 04:37 AM   #1
IAMFLAGMAN's Avatar
Year: 1982
Coachwork: Bluebird Wanderlodge
Chassis: FC35RB (Forward Control 35')
Engine: Catterpilar 3208NA
SKOOLIE BUS CONVERSION FOR SALE $2500.00
I have followed this forum for a few years now and I know that there
are a lot of talented people on here, so I'm offering this fixer
upper to anyone that is interested. I have owned this bus for twenty
years and originally used it to tow my race car throughout the
country and I now own a newer bus conversion and I thought that I
would have the time to fix the problems with the old bus, but I just
don't have the time to do it, so hopefully it will find a good home.
It has all of the major work done to it, that you would have to do to
convert a Skoolie, so there is little left to do. You can see some
photos of what it used to look like and what condition it is in now,
by going to;
http://www.pbase.com/iamflagman/image/24978855
1966 INTERNATIONAL HARVESTER CHASSIS / SUPERIOR COACH BODY 32' PUSHER
BUS
ORIGIANLL USED BY THE US ARMY AS A HIGHWAY TROOP/SCHOOL/ACTIVITY BUS
HAS AN UP TO DATE MOTORHOME LICENSE AND TITLE AND IS ALSO INSURED AS
A MOTORHOME
IH 392 GAS V8 ENGINE
FULL STEEL HEAVY DUTY BUS FRAME
ALL STEEL BODY, WITH THE EXCEPTION OF AN ALUMINUM ENTRANCE DOOR
FIVE SPEED MANUAL TRANSMISSION
11R X 22.5 TIRES ON STEEL BUDD WHEELS
Tires have good tread but are over eight years old and have some
weather checking
POWER STEERING
SAFETY-PLUS STEERING CONTROL
AIR BRAKES
BRAKE SHOES HAVE LESS THAN 5000 MILES ON THEM
REAR SPRINGS HAVE LESS THAN 5000 MILES ON THEM
FRONT SPRINGS HAVE BEEN REDONE TO CUSHION FRONT END RIDE
REAR RADIATOR RECORED AND HAS LESS THAN 5000 MILES ON IT
AN ADDITIONAL 12 VOLT ELECTRIC FAN HAS BEEN ADDED
AUXILARY FRONT RADIATOR WITH ELECTRIC FAN UNDER FRONT OF COACH.
(While pulling a toad, or a trailer with the race car, I have driven
up east coast grades on I-26 and I-77 with no overheating in the
summer months)
FULL UNDER BODY PROFFESSIONAL SPRAY FOAM INSULLATED, INCLUDING INSIDE
WHEREVER IT COULD BE DONE
IT HAS A 12.5 KW GENERATOR THAT NEEDS REPLACING, BUT THE FRAME IS
STILL USABLE AND ALL CONTROLS ARE INTACT AND USABLE
STEWART WARNER PUSHER FUEL PUMP FOR MAIN ENGINE
50 AMP CONVERTER CHARGER
120 VOLT 30 AMP SERVICE WITH A MANUAL SWITCH OVER SHORE
POWER/GENERATOR SWITCH
25 FOOT 30 AMP SHORE POWER SERVICE CORD, THAT STORES INTERNALLY
4 SIX VOLT TROJAN T-105 GOLF CART BATTERIES FOR HOUSE POWER
LARGE TRUCK/TRACTOR STYLE MAIN ENGINE BATTERY
60 GAL SEWAGE AND 60 WATER TANKS
FRONT AND REAR DOCKING LIGHTS
AIR COMPRESSOR FOR WATER TANK INCLUDES NEW SPARE COMPRESSOR
WATER SYSTEM IS SET UP WITH VALVES TO BYPASS TANKS FOR CITY WATER USE
IF YOU WISH.
WHOLE HOUSE FILTER, REPLACABLE CARTRIDGE TYPE.
ONBOARD PROPANE TANK WITH EXTERNAL PROPANE HOOKUP AND PROPANE GRILL
HOOKUP.
DISH NETWORK SATTELITE TV SYSTEM WITH STAND ALONE PORTABLE DISH
FINISHED INTERIOR
LARGE DINING TABLE THAT CONVERTS TO BED
QUEEN BED WITH EXTENSION (7' LONG TOTAL)
FRONT SOFA CONVERTS TO A BED
FRONT TV AND REAR TV CABLE HOOKUPS
EXTERNAL CRANK UP TV ANTENNA WITH SIGNAL BOOSTER.
REAR VIEW MONITOR CAMERA
6 CU. FT 120V/LP REFRIGERATOR
MICROWAVE
DOUBLE SINK
LP GAS STOVE
6 GALLON LP WATER HEATER
FANTASTIC VENT FAN
SEA-LAND CERAMIC LARGE SIZE TOILET (no small plastic type)
2 COLEMAN 13,500 BTU AIRCONDITIONERS WITH HET STRIPS
2 CATALITIC LP FURNACES
AM/FM/STERO RADIO
PLENTY OF CABINETS AND CLOSETS FOR STORAGE
THREE OUTSIDE STORAGE BAYS AND ONE PROPANE TANK STORAGE BAY
HORSE TRAILER STYLE FOLDING SIDE STEPS AND ROOF ACCESS RAILS
PLENTY OF ROOF AREA FOR CHAIRS TO WATCH RACES FROM
CONDITION;
I lived full time in this coach for the past fifteen years and
maintained it as a home, so everything inside works, but I had a
heart attack three years ago while I was in the process of getting
ready to repair the engine start and body problem and I had to delay
that and I have not been able to find time to get restarted on those
repairs since my recovery. I had been using the bus to pull my
formula race car and attend football games and I traveled throughout
the southeast and Midwestern states in it.
I have since purchased a Bluebird Wanderlodge and been spending all
of my time fixing it up and I now need the space. This will make a
good coach for someone who has the mechanical ability to do the
repairs. I believe that a new starter (the old one is still under
warranty I believe) and or starter solenoid, plus a carburetor
rebuild, will get it running again, as when the ignition is turned on
and the electric fuel pump runs, gas leaks out of the Holley
carburetor. When you try to start the engine, it will turn over, but
when you release the ignition switch, the engine continues to rotate
and then you have to remove the battery cables to get it to stop.
The hydraulic clutch should have the fluid flushed and then bled. The
other fluids and the belts should be changed also. I will provide all
of the filters and some spare belts.
It also has some rust on the steel panels that were installed by the
previous owner, they are a low grade of stainless steel and are
mounted using screws, this is an all steel bus, with the exception of
the aluminum entry door. The steel panels are replaceable. It has
been sitting under trees and needs a good power was to remove the
residue from the trees. It has primer paint in places now, as you can
see in the recent photos of the rusted areas. The Awning material
needs to be replaced.
With the engine running, the interior noise level inside this bus is
extremely quit, because of all of the additional insulation and in
order to hear the engine start, you have to open the drivers window,
or watch the tach. The ride is very good, since the front springs
were modified, as originally they were rated at 8000# each, which
gave it a very harsh ride and the actual front axle weight is only
somewhere in the 8,000# area.
I originally intended to fix the bus up myself and sell it for a
higher price, but I just don't have the time to do it now and I
really need the room, so I'm asking $2500.00 for the bus, with an
added incentive of a return of $500.00 of the $2500.00 selling price,
if it is removed from my property by June 1, 2006 so you can pick it
up for $2000.00. I do not want the repairs to be done on my property,
due to insurance reasons, so it must be towed from here immediately
after it is purchased. The reason for the June 1 date, is I plan to
leave here for the summer, shortly after June 1, 2006 and want the
bus moved by then, otherwise I won't return until September.
John Finn
Hopkins, South Carolina
803-783-7137
iamflagman@aol,com
https://www.pbase.com/iamflagman/image/124105919.jpg
JOHN FINN
'82FC35RB BLUEBIRD WANDERLODGE
"FINN'S INN EXPRESS"
HOPKINS, SC
FINN'S INN EXPRESS ALBUM
https://www.pbase.com/image/24977457
https://www.wanderlodgeownersgroup.com
IAMFLAGMAN is offline   Reply With Quote
29 buses for sale-$2500 each sdwarf36 Classifieds | Buy, Sell, Swap 4 06-24-2014 01:11 AM
New Skoolie Conversion and Old Skoolie Remodel jlhollowx13 Skoolie Conversion Projects 0 01-22-2013 01:41 PM
1986 Ford B600 for sale in VA - $2500 Skoolie_Tony Classifieds | Buy, Sell, Swap 2 08-28-2010 05:19 PM
1985 GMC diesel automatic bus 4 sale-2500-obo pyrazen Classifieds | Buy, Sell, Swap 1 08-27-2008 03:07 PM
88 GMC diesel short bus, $2500 greasewagen Classifieds | Buy, Sell, Swap 0 08-28-2006 08:22 PM
