06-17-2018, 06:58 PM
some advice please
Hello, we're Mike and Amy. We"re looking for a bus to convert. I've been reading posts here for over a year and although I've learned a lot I realize I still know very little.
I'm willing to travel but obviously a bus closer to home is appealing. I live in Fort Myers, FL. I'm hoping i can post a couple of the buses I'm considering and some of you experts (at least in my mind) can give me your educated opinions. I'd really like something about 25 feet but will consider up to 30. Thanks in advance
Just a little info: I'm very handy and the conversion does not concern me. I've never worked much on vehicles though. I'm hoping for something very mechanically sound. Hopefully that way I'll have learned more before the problems start.
Any knowledge, advice, fair prices I could offer... are greatly appreciated. Even if they're all lemons hearing why will help me.
Here are the contenders so far
https://spacecoast.craigslist.org/rv...570855841.html
(in state, low miles)
https://atlanta.craigslist.org/atl/c...612667257.html
(love the look, to expensive, hoping he'll sell without oven at reasonable price, 12hrs away)
https://atlanta.craigslist.org/nat/c...611698853.html
(a bit large? 12hrs away)
https://fortmyers.craigslist.org/col...596733369.html
(close to home, Shuttle style)
06-19-2018, 03:13 PM
No one?
06-19-2018, 04:05 PM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
The middle two
Keep in mind I don't know weak points of these kind of buses. Other people here know lots more than me.
The last one on your list -- weak point-- the body looks to be fiberglass. Appears to have damage already. I think this is not going to stand the test of time.
The bottom on your list has an engine, shows to be the benz four cylinder, that will not be well suited for highways.
The middle two on the list have that school/bus truck kind of chassis body. I think they are more durable.
Second on your list, what engine is in that thing?
Third on your list, the short wheel base means you are going to have to get used the overhang front and rear, but will turn in smaller spaces. Less crash protection for the driver, because of no front to take an impact. The 5.9 is a couple of liters short of engine displacement and you give away 100hp and 200 ft/lbs of torque right there. The upside to the cummins 24 valve 5.9 is that this is an engine found in dodge trucks and is pretty easy to get more power out of it, The pistons, connecting rods, crankshaft- what is called the long block is pretty strong. doubling the power out put is pretty easy with bolt on parts. The exception is at some point you should replace the head bolts with head studs. There are reams of information about this engine on the internet.
My vote is for number three. Longer but will drive like shorter bus, ample room, parts support for the engine and full size chassis/body, tough to kill. Negative, lack of crush zone on front of cab.
I bet you go with fire place wagon. Why? Because you decided already that you like it best.
Peace, be well, eat more ice cream, enjoy.
william
06-19-2018, 04:25 PM
Hi!
One thing you didn't mention is how much you want to be able to do yourself. That changes things a lot! If you're the type of person who would be goig to a dealer whenever something breaks, that changes the recommendations vs soeone who wants to be able to fix at least the common stuff themselves.
Most of us are in group #2, so I'll reply as if you are as well.
Bus #1: 2005 Thomas Short Bus, M Benz Motor, 44,700 Miles - $8500
MB engine means expensive parts from the dealer. Mostly only big rig shops will touch it. It's post-emissions and the first iterations of engines from these regulations (arguably everything since then too) are various forms of broken, ranging from grenade to boat anchor to just one more expensive part to replace every oil change or two. Price is way too high even if both ACs work it should be about half that much. This is not a desirable bus to begin with and having eaten one transmission already on top of everything else I wouldn't personally consider it at any price.
Bus #2: PARTY BUS - $12900 (Atlanta)
It's a Vista. My short bus is a Vista, so I know a lot about them. That wood stove is absurd! Looks like like a mobile blacksmith than a camper. All the new stuff sounds good, tires alone would set you back another $1500. The ad claims it has 1.2 million iles which I assume is a typo, if it's actually 120k then that's really nice. Didn't specify the drivetrain but it's probably a T444E and an AT545 like mine, which in that bus is great for around town but not ideal for the highway. They don't mention how much or what type of solar it hast, and I would bet that roof top AC needs to be plugged in to AC power to use. You can park a short Vista at Starbucks without a lot of drama. Of course, that price is crazy crazy! I wish the market for buses were so good that I could ask that much for mine!
Bus #3: 2001 Blue Bird Bus. 28 Passenger - $8500 (Woodstock)
These short transit style buses are as close as you get to being a chick magnet. They're pretty desirable buses largely because of how they look. THe short wheelbase works against you at speed but is really nice around town. Again, no mention of the transmission type but Id bet it's another AT545. Dual AC is great, the 24v 5.9 is a good motor but the 12v was fully mechanical (no computers required to make it run). For sure check the block stamping and make sure it's not a 53 stamp engine. ( Cummins 53 Block Casting Information ) gain, the price is too high. A friend just bought a similar model for about 1/3 that price.
Bus #4: 2001 Freightliner 31 Passenger Bus - $6500 (naples)
Strikes against it for the CAT engine, for having 360k miles, and for being painted black. Only someone who already has brain damage from heat stroke would paint a bus black in Florida! If you like the shuttle style vs a school bus, there are a LOT of them based on GM and Ford chassis that will be far less of a headache, and they aren't highly valued so you can get them cheap.
Out of the list you presented, I'd write them all off because of asking price.
I've written two articles I would suggest you read:
https://wanderlounge.net/are-you-con...us-conversion/
and
https://wanderlounge.net/how-much-sh...ould-i-buy-it/
06-19-2018, 04:41 PM
This is exactly the kind of info I was hoping for thank you both so much.
I'm definitely in the #2 group but as I've mentioned my mechanical skills are beginner. I'm confident I will catch on as I remodel homes for a living do tools are not a stranger to me. I certainly have some learning to do though.
If it's ok I'll post other contenders as they arise and certainly read the suggested articles.
06-19-2018, 08:26 PM
Take your time picking out a bus. Read a lot of "what bus to buy" threads and stuff and then start looking at buses.
The best buses are out west.
I'm up in Eustis FL and I don't buy FL buses. There are just much better states out there and most of ours are low spec stuff that gets beat on hard.
06-20-2018, 12:36 AM
Chassis: IH
Originally Posted by MikenAmy
1: 4 cyl, Mercedes engine, '05 model. *NO* Under-powered for highway use, parts only available at Mercedes dealers, and the numerous emissions systems will ensure many costly visits for parts and service.
2: As noted previously, it most likely has the T444 engine (excellent reputation and parts availability), under-powered in a full size bus but acceptable in a shorty. Trans is likely a AT545 (not highly desirable for much long distance cruising, but will do the job.) Price is a lot high.
3 : Listing says 8 cylinders; the 24V Cummins engine is a 6 cylinder. Pretty good reputation for the engine, trans is likely an AT545. The short wheelbase will be great for maneuvering in town, but a bit of a "bobber" on the highways.
4: The Cat engine is alright until it racks up some mileage; another Skoolie member bought one around Atlanta and it suffered a "loss of power" rather suddenly during the drive home. It was determined to be a fairly-common-with-this-engine injector problem and it is a dealer fix, for no small amount of money. Parts for Cat engines are *ONLY* available at Cat dealers, and they don't paint 'em "gold" for nothing. Good luck if you break down late on a Friday night ....
The black paint will be murder on temps any time the sun is shining. If you buy this one, I want some of the seats from it!
06-20-2018, 07:49 AM
Why aren't you on public surplus like the rest of us were? it's the end of the school year and a lot is out there
06-27-2018, 08:39 AM
Daunting perhaps?
I'm in the same situation as the OP. I'm looking for a good sturdy base to build a home in.
Please correct me if i'm wrong - Public surplus auctions seem to be something of a gamble to me to be honest. It's a bid on a bus online that you can't see (other than limited pictures) and if you're lucky you got a keeper. On the other hand you may also end up with a scraper.
Another thing i'm completely in the dark about is the registration. How do you pick up and drive off with a bus that is registered as a bus and not an RV? Would it require special insurance? CDL? other?
I can understand the opportunity here since the price is less than half, but how do you know what you're gonna get? If you are into it as a business I'm sure you can pick up a number of buses and on average you'll do okay. But as a one-time-buyer looking to find a sound bus to build our home in, gambling doesn't feel like the way to go.
Sorry for the ramble, but i've been trying to figure out how to approach this project and I feel that i'm getting lost in all the data. Just like a tag i've seen used by one of the users here "The more I learn, the less I know"
Thanks all, and happy hunting.
06-27-2018, 11:44 AM
Originally Posted by gingimen
Daunting perhaps?
As a one time buyer how do you know that you're not getting hosed no matter where you buy from, be it auction, CL, or other private sale. Keep in mind the auctions are usually selling buses that were just taken out of service from a regular maintenance routine. It is prudent to personally inspect whatever vehicle you are interested in to determine true condition. There are services available to do this if you're not confident on what to look for. Once you own it as a private owned vehicle you won't need a CDL. Licensing, registration and titling of a new purchase is discussed heavily here, do a search.
06-27-2018, 12:09 PM
Yes, what gingimen said!!!
Do I fly across country to look at auction buses i "might" want? I've been told not to buy florida buses so this seems especially risky.
I've certainly been on public surplus and govdeals but its very overwhelming to someone new to this.
06-27-2018, 12:27 PM
Yes, if you want to know for sure, you have to fly out there and deal with it, or takes your chances. I bought one sight unseen and found it to not be as described, was refunded my money, but still had travel expenses that I added into the cost of the bus I eventually purchased. It would have cost me the same to fly out and check it out to see it wasn't what I wanted. In my case I got lucky that they refunded all funds. They could have told me to pound sand and get my bus off their lot. Buying any used vehicle is Caveat Emptor, buyer beware. I was ready to jump in and buy a bus 6 months ago, in that 6 months I learned I was NOT ready to buy a bus 6 months ago. The knowledge gained in the next 4 months was extremely helpful in making a proper decision on a purchase. Keep asking questions and you'll get what you want. Haste makes waste.
06-27-2018, 12:42 PM
Year: 1994
Engine: DT408 6.7L L6
I chose to buy a bus sight unseen from an auction. In my case I was able to drive it the 300+ miles home with no issues. Some of the recommendations I would make are;
1) Try to find a local bus (driving distance). This can be done on GD or PS, but you might also try finding other less known auction houses. I found one in TX that serves the surrounding states.
2) Call or email (or both) the school district who owns the bus, talk to the transportation department, and ask them directly about the condition of the bus. Ask them if in their opinion it is safe enough for it maiden voyage. Have an extensive set of questions to ask them (tires, rust, A/C, brakes, PS, etc...)
3) Ask them to do a final once over (fluid check, etc...) after you've bid/won the auction. In my case they did. This means I didn't have to take it to the shop before driving it home.
4) Realize that even if you crap out and buy a junker, and have to buy another one, you're still coming out ahead ($) of the person who buys from a dealer as their markup is 3-5x from what I've seen.
5) Don't buy from a dealer unless it is EXACTLY what you want; powertrain, capacity, options, condition, etc... Why pay a premium if you won't be thrilled with the purchase?
6) Update your profile so we know where you are. The community here is extremely nice and will doesn't have issues helping you find a bus that fits your needs in your location.
06-27-2018, 12:59 PM
Rated Cap: 35
Hello and welcome Mike and Amy. for what it is worth my search for a bus took 8 months. during that time I was able to research a lot on this site and finally found my bus just a 90 minute drive away. Research and watching trends of prices on auction sites is invaluable. you can see my bus on my build thread which is linked below. I paid $2200 total out the door.
06-27-2018, 01:28 PM
Loving your thread Rovobay. Thanks
06-27-2018, 06:24 PM
How about this one?
https://fortmyers.craigslist.org/chl...601755478.html
I like the size and the 5.9 Cummins 12v
No mention of trans but I'm assuming Allison545?
Being in state is another bonus. The price seems high.
I'd love to hear what y'all think. What are the negatives here? What would be a good and fair offer? Thanks in advance for the help.
06-27-2018, 07:08 PM
Chassis: Saf-T-Liner MVP ER
How about this one?
This one is being sold by a bus-flipper and he is completely over-blowing what he has.
My guess is that he picked it up at auction for $2500.
06-27-2018, 07:15 PM
Agreed, messaged him and this one had a deposit but he's giving me the sales pitch on others. Thankfully I have a little knowledge from this site.
He's telling me that a dt466 7.6l is better then the Cummins 5.9
I'd love to hear opinions on this as the Cummins seems to me to be the engine of choice around here.
06-27-2018, 08:12 PM
The mechanical 5.9 is a great motor, it's still a 5.9 so you can get a lot more muscle out of something bigger. His price is nuts though, that's not a particularly desirable bus in general. He sure talks it up but that's what sellers do.
It's easy to say having been into buses for a while, but the price range you're looking at suggests you should have your pick of most any type of bus. So what bus do you want? Be less concerned about what's on craigslist that you can find today. You should already know how you intend to use your bus. Is it a home or is it a ocasional camper? Are you staying somewhere or travelling? What amenities do you need to fit inside? Do you plan on towing another vehicle?
To answer your question, the DT466 is much more powerful than the 5.9 cummins, and is also a great motor. Pretty much any pre-2004 Navistar or Cummins engine will be favored here. The mechanical 12v 5.9 is very popular for being able to maintain it yourself, but not a great choice for a 40 ft bus pulling a toad up the mountain.
06-27-2018, 08:26 PM
He's completely right about the DT466. I don't know where you found here that the 5.9 was a "desired" motor". It is generally at the bottom of the desirable list, with only the 24v as being less desirable. Notice I did not say it was bad motor, it just has it's place. There were a lot of buses I could have had that clicked all the boxes except the 5.9. I'm glad I waited for the DT 466, I would have regretted it for the rest of time.
