Old 02-12-2008, 05:59 AM   #1
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Re: Suggestions for buses with good MPG?
Originally Posted by swanfist
I have a 78 gillig bus with a 350 cummins big cam. Great power but horrible mileage. averages 5-6 mpg.
I've seen posts from folks with bluebirds that are getting 10+mpg going 65-70 mph.
I would consider selling my gillig if i could be sure I'd get twice the mpg with a bluebird.
Any suggestions on exact engine/year/body type I should consider?
thanks!
If you want the room, you could go with a Crown. Traveling from Phoenix to Houston, I got 9.5 to 10 mpg while towing a car and carrying a house load of furniture. Not bad for a 37 footer weighing in at 21,000lbs empty.
BTW, that was with a 671 DD and a five speed fuller.
Roasting8 is offline   Reply With Quote
Old 02-12-2008, 09:58 AM   #2
phillbus914's Avatar
I've only been on a few log trips with my bus, about 2 years ago we went to South Padre Island TX for spring brake with it - and I documented my fuel usage. When I got home I put it into the table below. My speed-o is off, it reads 11% slower than you are actually going. I figured this amount by calculating the mileage mapquest stated vs. the mileage my odometer read. The mileage in the right column is the corrected fuel mileage.
For the entire trip I averaged 8.3 MPG
On the way down I followed Jason's bus which maintained his top speed of 65mph. At that speed I averaged around 9mpg (one tank was almost 11)
On the way back, we left before Jason and traveled at my bus's top speed (70-75mph) and got much worse fuel mileage. One tank we got as low as 6.17MPG - this was driving at wide open throttle for an entire tank of fuel. A few tanks later we went a steady 55mph and got 12.89MPG.
Speed, wind direction and terrain all play a huge factor in fuel mileage. For planning trips I estimate mileage at 8mpg to cover my fuel expenses, and I try to drive 60-65 mph to get the best mileage. If I drive it right I should be able to get 9-10 MPG.
My bus has a cummins 5.9 turbo & innercooled with AT545 (I think) and 4.33 gears. Also it's got the aerodynamics of a barn.
My Old Bus :(
Old 02-15-2008, 12:16 AM   #3
Year: 1987
Engine: DD 671
Rated Cap: 73
What type of transmission are you running? Sometimes changing from an automatic to a manual can save lots of fuel. If you can find a 10 speed, there is nothing better.
sauce is offline   Reply With Quote
A couple of good buses up for auction dan-fox Classifieds | Buy, Sell, Swap 2 08-25-2014 09:29 PM
Looks like some good buses on public surplus in washington. Locutus Classifieds | Buy, Sell, Swap 3 09-23-2010 12:51 AM
Good buses for low money frank-id Classifieds | Buy, Sell, Swap 0 08-03-2010 01:35 PM
Two good buses for sale in SW Idaho- Pictures dburt Classifieds | Buy, Sell, Swap 2 11-10-2009 05:32 PM
Two good buses for sale in SW Idaho dburt Classifieds | Buy, Sell, Swap 0 10-02-2009 02:48 PM
