Old 09-28-2013, 08:36 PM   #1
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
Swivel van seat mount.
If you have one and you'd like to get rid of it, I'd be eternally grateful.
Let me know what you want to get it to 56307.
Passes everything but gas stations.
bamper is offline   Reply With Quote
Old 09-30-2013, 12:18 PM   #2
Engine: 190hp 5.9 Cummins
Re: Swivel van seat mount.
I like that quick release as long as the seat belt attaches to the floor, not the seat.
I was just going to fab some up using a simple 1000 pound trailer stub axle. More than strong enough, and cheap. All you need is to weld a plate on the bottom to bolt to the floor, and the seat would bolt to the lug bolts.
Old 09-30-2013, 05:07 PM   #3
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
The belts mount to the seat, how else would you get it to swivel whilst driving ??
Thousands of these were mounted in vans over the course of a few decades so I would think that it's plenty strong/safe to use the quick release to secure the seat down.
If I don't find one before the bus goes back in the shop to go under the knife again I'm going to build one. It's just too attractive to have the drivers seat easily removable with all the electrical crap and defroster/heater core crammed to the left of it.
Old 09-30-2013, 05:14 PM   #4
That's. 3/16 and 1/4 steel....if "it" breaks I don't want to be in it when it hits something big and heavy enough to break it.....I'm pretty sure whatever is occupying the first 10 feet of the coach,would make sure you don't remember it.
Looks like weak link would be the dowel pin,it breaks/shears... then the "rails" come into play....it does slid into rails,to locate bottom "U" and then slids and then latches....if that is how it works...id driv it
Oh and why do "you" need it to swivel when driving?....so you can make a sammich?
On pirate years ago someone built some out of dom tubing,grease fittings and all,very cheap and worked great
Old 09-30-2013, 06:16 PM   #5
Year: 1977
Coachwork: Chevy
Chassis: C/60
Engine: 350 V8
Rated Cap: 54
Haha, no need to swivel while driving and I can just holler behind me for a sammich ;)
I was thinking of keeping the swivel so you can turn sideways and use that seat as more space whilst parked.
Old 10-01-2013, 05:25 AM   #6
that's what Lisa wants, so I am redoing front seat (also she wants it about 3" lower so she can see out windshield better)
Old 10-01-2013, 09:31 AM   #7
If the front of the seat is to the left, it would be plenty strong. If the front is to the right, there is no way I would trust that little tap of steel on the twist handle.
I've had a few vans with the swivel seats. What I didn't like was when I loaned it to a friend and he hit a approach. It sheered the 3/8th center bolt right off, spewing all the little ball bearings everywhere. The steering wheel is all that saved him from being ejected through the windshield.
Things hitting the back of the seat in a forward impact would make it worse. When I drove tow truck, there was a fatality at only 80kmh due to a ceramic diner plate hitting the man it the back of the head.
Be safe guys. Just my opinion.
Roof Racks/Deck... Side mount vs. roof mount? TygerCub Conversion General Discussions 37 08-14-2018 07:57 PM
Where to mount the propane tank lbranin Alternative Fuels | Electric, Propane, Wood Gasification, etc. 13 06-13-2018 07:32 PM
Threaded rod to mount tanks White99z Conversion General Discussions 6 11-30-2014 03:59 PM
seat swivel base needed Diesel Dan Classifieds | Buy, Sell, Swap 7 02-19-2010 09:12 PM
How to mount tanks underneath? Diesel Dan Plumbing, Water and Waste 3 12-14-2009 11:28 AM
