04-08-2017, 05:58 AM
#21
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
So after a lot of watching, bidding, searching, and confusion I have a bus. I will be picking up a 2002 Bluebird AA RE on Monday. It's from Kerlin and they really went out of the way to get me what I wanted in a bus. Barring any issues at work, I will be heading out Sunday and driving back Monday.
04-08-2017, 09:51 AM
#22
That's exciting!
How many windows? Which engine and transmission?
04-08-2017, 09:57 AM
#23
Chassis: Bluebird
Rated Cap: 72 pax
Originally Posted by Rameses
That's exciting!
Cummins 5.9 and Allison 3060
04-09-2017, 02:26 PM
#24
Chassis: Bluebird
Rated Cap: 72 pax
Ok on the train to Indiana. Will be in Elkhart tomorrow morning and making my way to Silver lake by noon I hope.
04-09-2017, 11:56 PM
#25
That sounds awesome.
I love adventurous trips like that.
04-10-2017, 12:12 AM
#26
Chassis: Bluebird
Rated Cap: 72 pax
Totally unprepared. Lol
Walked out and left a bag behind in the car. Nothing that will end the trip, it just makes my life a bit harder.
04-10-2017, 03:39 PM
#27
Chassis: Bluebird
Rated Cap: 72 pax
I got a field trip bus. I keep having to let off the gas cuz it wants to do 70
04-10-2017, 03:44 PM
#28
Sounds like yours probably has a 4.78 rear end, like mine does.
They aren't very common in buses with an overdrive. Normal gearing behind an MD3060 is a 5.38.
04-10-2017, 03:45 PM
#29
Chassis: Bluebird
Rated Cap: 72 pax
It doesn't even strain
04-10-2017, 03:46 PM
#30
Chassis: Bluebird
Rated Cap: 72 pax
65 miles an hour is 2200 RPM
04-12-2017, 08:07 AM
#31
Ahh, that's right. I forgot you have a 5.9, which spins up higher. So you probably do have a 5.38 rear end. It looks like 2,200 rpm at 65 with a 5.38 and a .75 OD would put your tire height right at 40 inches. That means you probably have 10 22.5's or 22.5 low profiles (295/75 22.5's).
If all of my assumptions are correct, when it's time for new tires, you could gain a few more mph on the top end by switching to 11 22.5's.
04-12-2017, 08:13 AM
#32
Chassis: Bluebird
Rated Cap: 72 pax
They are 11r 22.5 now. I have to look at the rear end ratio. It spins up to 2700 according to the spec sheet. I haven't had it over 2300 and don't plan on it. It makes its best torque at about 16-1700 I think.
04-12-2017, 08:24 AM
#33
How much tread is left on your drive tires?
04-12-2017, 08:27 AM
#34
Chassis: Bluebird
Rated Cap: 72 pax
They are pretty decent. I didn't throw a gauge on them, but they are pretty deep.
04-12-2017, 08:29 AM
#35
Chassis: Bluebird
Rated Cap: 72 pax
One steer tire is a bit worn, the other is almost new. Plan on a new set of steers when I get it completed.
04-12-2017, 08:33 AM
#36
Interesting. You might have a slightly higher (numerically) gear ratio then.
If you put two new steers on it, then you could save the almost new one for a spare.
04-12-2017, 08:34 AM
#37
Chassis: Bluebird
Rated Cap: 72 pax
That is the plan. The rears are the chunky all terrain looking tread.
04-12-2017, 08:41 AM
#38
Chassis: Bluebird
Rated Cap: 72 pax
So here come the questions.. lol
First. My bus had the no child Left behind (bus driver has to hit a button to silence an alarm) that the dealer disabled with a key. Anything special about removing that? It's on all the time.
04-12-2017, 08:48 AM
#39
Chassis: Bluebird
Rated Cap: 72 pax
Here is where the oil is leaking from. Can't see the actual leak until I clean it up
The slobber/bypass tube comes down the front of the timing cover... It has a valve on it. I have to check that and make sure it's open. Any little bit of blowby would blow out the seal if there was no vent open...
Another thing on the to-do list 😂
