Old 06-24-2017, 02:21 PM   #1
miltruckman's Avatar
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
Two 45 gallon water tanks free to first to haul them away
I have two 45 gallon water tanks I had built for my bus but never used. They are cylindrical tanks 50" long by 20 inches in diameter. They are made out of hdpe pipe with ends plastic welded on. One has one inch ports for a fresh water tank, and one 2" ports for a waste tank. They are incredibly tough and will probably never leak as they are 1-1/2" to 2" thick plastic. You could probably literally run over them with a bulldozer and they would be fine.
The first person to show up and haul them away gets them. I'm cleaning out the garage.
Bill
Birch Run, MI
Home phone: 989-624-4802
Wap@wprestin.com
miltruckman is offline   Reply With Quote
Old 06-24-2017, 02:25 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Wish you were closer
Old 06-24-2017, 03:34 PM   #3
Jolly Roger's Avatar
Engine: Detroit 8.2
Bill
Birch Run, MI
Wap@wprestin.com
Just want to keep this going.
I know what it cost material wise to make them cause I work with the stuff and wanted to build my own like that.
Somebody closer to bill in Michigan can makes them work and if someone does get them and can't understand what they are looking at. I am sure bill can tell you his idea for design and I and the rest of the group can help you make them work.
Old 06-25-2017, 09:06 PM   #4
Engine: 5.9 cummins
These tanks are still available...
Bill
